Go Back   Automotive Forums Car Chat > Toyota > Tacoma
Old 05-18-2004, 09:15 PM
TacomaPilot's Avatar
TacomaPilot TacomaPilot is offline
Air Horn Installation
Has anyone installed air horns on thier Tacoma? I have an '02 and would like to install some, however I'm not sure which wire to tap into. Any suggestions or tips would be appreciated. Photos would be even better.
Old 08-22-2004, 11:05 PM
dspain01 dspain01 is offline
I mounted them on my 2000 Tacoma under the opposite side of the electric horn. That would be mounting them on the driver's side. You need to mount them horn facing down (as to not get any rocks or debris in the horns) and you can mount both horns and compressor on the undercarriage right behind the valence.
I ran a wire from the compressor to the original electric wire (single wire) and then just T-tapped into it. The second wire will need to be grounded onto the chassis right next to the compressor was the easiest.
You will want to leave the electric horn hooked up due to the fact that i found that I can't hear my alarm "arm" itself with the quick pulses of air coming from the air horns. And having more sound isn't that bad either.
e-mail me for pics ([email protected])
