Go Back   Automotive Forums Car Chat > Toyota > MR2/MR-S
Old 05-18-2004, 08:02 PM
kmak686's Avatar
kmak686 kmak686 is offline
Send a message via AIM to kmak686
vtech head?
can i put a honda b20 or k20 not sure vtech head on mai 1991 mr2 turbo
i thought i might be able to because there both 2.0 liters. and have u guyz heard of neone doing this before? thanks
Old 05-19-2004, 01:35 PM
MR2Driver's Avatar
MR2Driver MR2Driver is offline
Re: vtech head?
Did you post this on the MR2OC?
Either way, no, it wouldnt fit, at all, if you wanted a "VTEC" head on a MR2 you should use the VVTI Beams 3S-GE head. But why would you want to? Boost > VTEC.
This might be the dumbest idea i've ever heard, keep Honda parts on hondas...
Old 05-19-2004, 05:58 PM
kmak686's Avatar
Re: vtech head?
y is it the dumbest idea ever, have u ever been in a boosted b18. its awsome and then when the vtech kicks in its klike double boost(in a way)
Old 05-19-2004, 07:07 PM
HondaChili's Avatar
HondaChili HondaChili is offline
Send a message via AIM to HondaChili
a friend has told me before that when u turbo charge a vtec system, depending how many pounds, when u boost when the extra cam opens up you would actually push air out of the system through the vtec instead of using it to get more air. Thats why most people turbo charge LS integras instead of a gsr model. I may be wrong but thats what a friend told me before and it doesnt seem to be bull.
It's All About The FINNESSe!
X 1993 MR2 Turbo X
New Project - 1997 Toyota Supra TT Limited Edition.
Old 05-19-2004, 09:43 PM
MR2Driver's Avatar
Re: vtech head?
1st of all my Integra had a B18. 2nd of all VTEC and boost dont go well together, because you dont stay in the HIGH rpms.
The reason the LS is the preferred forced induction application is because of its longer gears and lower compression ratio. I know my Honda knowledge, but to VTEC a Toyota turbocharged engine would be counter productive.
There are already much better ways to make power on the 3S-GTE than to mess with the head like that.
I've ridden in many a Turbo GS-R, and it FELT faster than it was. I prefer real power... Boost > VTEC
Old 05-19-2004, 11:24 PM
kmak686's Avatar
Re: vtech head?
alright thanks for the info i guess it just seemed faster than it was
Old 10-10-2004, 06:40 PM
NOFOOLIN NOFOOLIN is offline
Send a message via ICQ to NOFOOLIN
Re: vtech head?
putting any honda parts on an mr2 is an abomination
Old 10-10-2004, 06:46 PM
ghetto7o2azn ghetto7o2azn is offline
this thread is old
Old 10-11-2004, 11:56 AM
willowlee willowlee is offline
vvti and turbocharge?
so if this (boost > vtec) was true, can this be also true (boost > vvti). will a 3sgte engine with vvti be weaker than a 3sgte engine without vvti? just wondering.............
Old 10-11-2004, 05:39 PM
TRD2000's Avatar
TRD2000 TRD2000 is offline
Re: vtech head?
it depends on your tuning... it takes a lot to get a vvt system to work nicely with a turbo.
i'm planning on building a 3s-gte from a Beams 3s-ge, will be using motec ECU to control valve overlap to avoid "blow through". it's possible to get it to work well but it REALLY depends on what you are using the car for, you can get just as much power without rhe VVT system, especially at the top end, VVT makes no difference.
i dont want to go into this but its all about the cam shape.
Who needs AWD? i feel inspired by the original 911 turbo, my car will have more rubber sqeezed in its ass than Annabelle Chong! and it will go down as one of the greatest rides in history!
Old 10-13-2004, 01:45 AM
1ofthesedays's Avatar
1ofthesedays 1ofthesedays is offline
Send a message via AIM to 1ofthesedays
Re: vtech head?
why the beams 3sge? you could just get a regular 3sgte...
did you guys notice the thread started spelled vtec "vtech"? haha.
SW21 SMG N/A Hardtop
Old 10-13-2004, 01:42 PM
TRD2000's Avatar
Re: vtech head?
the regular 3sgte doesn't have VVTL-i.
its the harder way to do it, thats for sure, but when i get it all done it should work really well.
the low cam profile is close to a 3sgte cam, and the high cam is close to an extreme HKS cam. so i could drive round on a normal cam below boost and even continually adjust the timing to make it more efficient, then when i put my foot down it hits the big cam and the boost and i'm off... well it'd hit the boost first. also the altezza (beams) engine revs harder, stronger springs etc. figured out i'm gonna use a motec EMS to run it all so i'll be able to up the rev limit.
