Go Back   Automotive Forums Car Chat > Jeep > Grand Cherokee | Grand Cherokee SRT8
Old 05-18-2004, 01:28 PM
ISRAEL NUNEZ ISRAEL NUNEZ is offline
Angry Stalls And Cuts Off
I Have A 1995 Grand Chorakee Lim, Light Driving Runs Fine But After Long Drive Car Stutters And Cuts Off, I Let It Cool Off For 30 Min Runs Fine But Then Shut Off Again After Riding Again, I Notiece That The Oil Gauge Drops, I Gave It A Full Tune Up Change Oil Senser Also, What Can Be The Prob
Old 05-19-2004, 08:18 AM
98cam 98cam is offline
Re: Stalls And Cuts Off
The same symtom was happening to a 94GC 5.2 I own. After research I replaced the fuel pump and fixed the problem. As I recall it has something to do with a detail that when heated expands and prevents other parts from turning thus seizes the pump. I drove the Jeep for 2yrs. like that and finally left me stranded.
Old 06-03-2004, 07:38 AM
yxe2yyz yxe2yyz is offline
Smile Re: Re: Stalls And Cuts Off
When you are driving and the engine just suddenly cuts off but all your electrical (radio, lights, etc) are still on, the problem is your crankshaft position sensor. I had that problem last year with my 94 JGC. After having the sensor replaced, it had never happened again.
Happy truckin'.
Old 06-13-2004, 09:23 PM
leowolf leowolf is offline
Re: Re: Re: Stalls And Cuts Off
does the oil pressure drop to nothing before the engine does? if so it might be prudent to check the oil pump. if the pick up tube is leaking it could cause catostrphic failure.
Old 09-09-2004, 01:02 AM
dksob81 dksob81 is offline
Send a message via ICQ to dksob81 Send a message via AIM to dksob81 Send a message via MSN to dksob81 Send a message via Yahoo to dksob81
Would u send me (Joe, [email protected]) a pic of your Vacuum harness that is connected to the EGR Valve, both Sides of Intake Manifold, Fuel Pressure Regulator, Purge Solenoid, etc... Please, I need to make one, the dealer says it is discontinued and unavailable to them and that I would have to improvise (which means make my own). I had a fire and burnt the vacuum lines up.
Old 09-09-2004, 11:40 AM
change the coil.
