Go Back   Automotive Forums Car Chat > Toyota > Supra > Performance
Performance Talk about anything having to do with performance & mods.
Old 05-18-2004, 12:22 PM
89supradude 89supradude is offline
Question chip tuning/timing?
i have an 89 Turbo Supra, and it runs pretty rich. It's completely stock except for adjustments on the waste gate to give me more boost. I was wondering if there is any chip burning hardware/software or chip vendors that make chips for this car. Also, if there is any other way to adjust the timing on these cars to try to lean it out, that would be helpful. Thanks!
Old 05-18-2004, 07:39 PM
projectsupramk3's Avatar
projectsupramk3 projectsupramk3 is offline
Send a message via AIM to projectsupramk3
Re: chip tuning/timing?
We don't have domestics with replacable chips, so you'll have to either use a piggy back A/F controller or a full standalone. There are tons of air/fuel controllers out now, one of the best and most common is the Apexi S-AFC. Also I would suggest not touching anything unless you have a wideband O2 sensor and/or a EGT gauge. It's not hard to blow a 7M if you lean it out too much. MKIII's run pig rich natrually, more safe for you, more safe for the engine. Did you shim the WG to up the boost?
