Old 05-18-2004, 11:53 AM
OverrRyde OverrRyde is offline
Send a message via ICQ to OverrRyde Send a message via MSN to OverrRyde
Best way to clean engine
Hey guys, small question
I just bought a 1990 Civic DX and the engine is somewhat dirty and id like to get it as clean as i can!
Anybody have any tips on what products to use or technics?
Thanks!
Old 05-18-2004, 12:15 PM
turtlecrxsi's Avatar
turtlecrxsi turtlecrxsi is offline
Send a message via AIM to turtlecrxsi
Re: Best way to clean engine
Go to Walmart or a similar store you prefer. Go to cleaning products aisle and buy "Goo Gone" It's a cheap way to remove built up gunk on engine parts. It took some time but it did quite a nice job on my intake manifold (without removing it). You can always go to auto part store and spend two to three times as much for some engine cleaner though.
Old 05-18-2004, 01:16 PM
89crx 89crx is offline
Simple green is awsome.Spray it on,let sit for a while, spray off.
Old 05-18-2004, 01:47 PM
90civicracer's Avatar
90civicracer 90civicracer is offline
Send a message via AIM to 90civicracer
Just don't put Simple Green on your hood. Josh (91lxdreamer) found that out the hard way, lol.
***90 Civic EX 4 Door***
Ace$nyper: yea it did woo woo 4500 posts i should be ashamed *kills self*
90civicracer: haha you killed yourself you got
Ace$nyper: OMFG LOL that might be the funniest thing you EVER posted
bwhahahaha
Old 05-18-2004, 02:36 PM
BullShifter's Avatar
Re: Re: Best way to clean engine
Steam cleaning is the best & safest way. Other than that you can use any degreaser or engine cleaner. Warm engine for 5 min max before cleaning.
Pressure washer is safer than garden hose "if" used correctly.
1. Clean under side of hood
2. Spray engine compartment with water
3. Spray cleaner, work in 4 section(do not allow cleaner to dry)
4. Scrub, rinse
You may need to do it a couple times. Don't spray water directly at electrical parts(alt, distrib, sensors, etc.)
After engine is cleaned & still wet spray some WATER BASED dressing over the entire compartment. Close hood & start/run engine until dry. Clean delicate parts with rag or brush. DO NOT USE TIRE DRESSING!!!! ITS SOLVENT THAT CAN/WILL START A FIRE. Plus solvent based is bad for rubber hoses, they will crack sooner.
Old 05-18-2004, 03:48 PM
redturbo66 redturbo66 is offline
steaming
Old 05-18-2004, 07:11 PM
TheSilentChamber's Avatar
TheSilentChamber TheSilentChamber is offline
Forunn Daberator
Take it all apart, bead blast the motor and engine bay, repaint everything and put it back together.
Accually I like SuperClean. Spray it and let it sit, use a brush to get the hard stuff .... pretty much what everyone else said.
Old 05-18-2004, 08:30 PM
shaddr3 shaddr3 is offline
Send a message via AIM to shaddr3
go to Jims Air or your local equipment renting place. Rent a sand blaster and just blast any piece of dirt you see, it should most deffinitally clean it up.
89 CRX Si
B16 | BW Body kit | 17" 8 Spoke | Airbagged
Old 05-18-2004, 08:45 PM
Cjz89civic's Avatar
Cjz89civic Cjz89civic is offline
AF Premium User
Send a message via AIM to Cjz89civic Send a message via Yahoo to Cjz89civic
After that heres a trick and it will make your engine bay look Like brand new. Go to your local auto parts store buy TURTLE WAX'S 2001 that green bottle and orange writing.
1. wet enige with a hose
2. spary a lot of the 2001 on the engine all over even on the battery and engine bay making sure you dont go over board and get it on your window and fenders (especially if you just washed the car)
3. close hood wait for about 2 hours
4. open hood and you will say "OMG it looks so good I could just sell this car on the engine bay alone" Really though it will look really good. It lasts for a long time too.
Mods: D16Z6 Turbo'd P28 ecu and Greddy emanage for fuel. FWD tire smoker
My first Civic love Died from 92 year old Fart not watchin out.
Old 05-18-2004, 09:03 PM
is there any places to be careful about though? your distributor and alternator right? what about your A/C if you have it?
89 CRX Si
Old 05-18-2004, 09:07 PM
FourthGenHatch's Avatar
FourthGenHatch FourthGenHatch is offline
Send a message via AIM to FourthGenHatch
http://www.fourthgenhatch.com/engineclean.html
Old 05-18-2004, 09:18 PM
Cjz89civic's Avatar
AF Premium User
Ya dont go overboard if your dist has the seal your ok the alt is ok to get wet the a/c would be the only thing cause of the belt also the alt belt. But other than that it works great.
Never saw that link but ya like that. Works great.
Old 05-18-2004, 11:08 PM
Forunn Daberator
before and after dont look much differnt
Old 05-19-2004, 12:01 AM
CZ-R's Avatar
CZ-R CZ-R is offline
Send a message via AIM to CZ-R
I always use the Simple Green method myself. Once you get all the grease & dirt cleaned off, spray everything under the hood with any brand of "tire foam" you like/use. It'll make all your hoses, wiring, etc... shine like new!
Old 05-19-2004, 12:09 AM
thanks for the replys guys! i think i want to go with the Simple Green solution, but i looked it up in canadian tire (i live in Montreal, Quebec) and they dont seem to have any...
Is there someone here from same region or near you knows where to get some? or maybe a substitute for it?
thanks!
