Go Back   Automotive Forums Car Chat > Honda > Wheels/Tires/Suspension
Wheels/Tires/Suspension All the handling help you need. No matter what Honda/Acura you drive.
Old 05-18-2004, 11:12 AM
jajimo's Avatar
jajimo jajimo is offline
Best Brake Pads
I thought W/T/S would be the closest related forum so I posted this hear.
The pads I have are cheap as hell and sound like shit (came with the car when I bought it). They squeak constantly (I've disassembled the rotor and inspected the pads, they're not worn down) and occaisionally when I brake, they sound as if they aren't grabbing the rotor enough and make a sort of crunkling sound.
I want to buy new pads, atlease for the front and I'm looking for ones that provide atleast OEM spec stopping power. Some performance would be great, but more importantly I'd prefer that they don't sound like shit. It's embarrassing when you drive somewhere and your brakes are squeaking like mad.
These are for a '94 Accord Sedan w/ABS.
Check out more pics of my 1994 Accord Sedan on CarDomain.com.
JDM Black Housing Headlamps, RS*R ExMag Cat-Back, H&R Sport Springs, AEM Short Ram Intake, Redded Out Tail Lights, DIY Mugen Grill, Graphite Emblems.
Old 05-18-2004, 02:27 PM
BullShifter's Avatar
Re: Best Brake Pads
I use EBC Green stuff on my Civic
Ceramic type pads will be the "best" type for street use. Just dont go overkill and get yourself some "race"pads. You'll never be able to keep them hot enough for them to function correctly.
Have your rotors resurfaced before installing new pads.
Old 05-18-2004, 11:06 PM
CivicSiRacer's Avatar
CivicSiRacer CivicSiRacer is offline
Civic Mod
Send a message via ICQ to CivicSiRacer Send a message via AIM to CivicSiRacer
Re: Best Brake Pads
That is one of the important things to resurface your rotors when you change the pads. Or at least sand them down with some 400 grit sandpaper.
What happens is the pad and rotor become "one" and when you throw on a new set of pads on the old rotors, the pads are not grooved to the old rotor.
I recommend AEM pads. I used them for 2 years with great results in autocrossing.
Sponsored by: KAM Racing Sports, Falken Tires, Finish First Polish, Brady's High Performance, Taggart Performance Engineering, Rotora Brakes
Autocross is: 90% driver, 5% car, & 5% CRAZY MOJO!
Autocross Help Page
Buy my Civic parts!
Old 05-19-2004, 07:38 PM
jajimo's Avatar
I may do that, I was reading some reviews on the EBC Green Stuff and it seemed to be sort of hit and miss. Sometimes you get good ones, other times really shitty ones. Not a whole lot of reviews for AEM pads. Are they ceramic also? Noise is definitely an issue.
Old 05-19-2004, 07:47 PM
SilverY2KCivic's Avatar
SilverY2KCivic SilverY2KCivic is offline
Cali Guy
Send a message via ICQ to SilverY2KCivic Send a message via AIM to SilverY2KCivic Send a message via Yahoo to SilverY2KCivic
Re: Best Brake Pads
Chalk another for AEM pads, I use them currently on my Civic as well and auto-X with them. They are basically similar to the OEM pads that Honda sells, but they have a slightly more aggressive compound they use to allow them to "bite" better and allow you to stop more efficently. I paired them to a set of Power Slot rotors. Mine I've never heard a single squeak or even sound from since I've had them. I'd recommend those (can be had for a good price from www.coximports.com) or the Hawk HPS pads that can be had from any Pep Boys store. The Hawks run about $40-$50 depending on the car, and the AEM's should be about $5 cheaper.
Silver '00 Civic EJ6 Coupe
PureHonda original member since Feb. 2000
D-series revolution For pics of my baby, click here!
All rights reserved... All BITERS served!
"The last time you had THIS much fun driving a car, it cost a quarter, and gyrated in front of the supermarket."
i have yet to see any well done imports around here. most are road toilets driven by some high school punk -Drift
hessemer69 on AIM
Old 05-19-2004, 07:48 PM
knucklebuster2 knucklebuster2 is offline
Noise is created by vibration. Although it may be from the pad material, it is also from poor condition brake hardware, rotor finish, loose or missing shims. My best experience has been with ceramic based pads. Most brake manufacturers have a ceramic line. My favorite is Raybestos. They also come with shims, anti rattle hardware and caliper lube. Whenever you use pads with shims, don't use brake squeal stop (spray-on or paste.) This will adhere to the shim and pull it away from the pad which will cause noise. Just use a little caliper lube on the back of the shim and you'll be fine. Proper rotor finish is also important for long pad life, proper braking (and pad brake-in) and no noise. Good luck!
