Old 05-18-2004, 03:48 AM
mjohn mjohn is offline
1995 5-speed with 175,000 miles Clicking
When I turn left and start out I hear clicking in the front axel...
If this is the CV joint...how hard is it to replace and where can I obtain the parts at the best price?
Thanks...MJohn
Old 05-18-2004, 07:46 AM
HONDA_99 HONDA_99 is offline
Re: 1995 5-speed with 175,000 miles Clicking
it's CV joint and i recommend to replace entire axle, it will little more expensive but whole a lot cleanner and faster.
to replace axle you need to remove wheel hub nut (~27-32mm), disconnect tie rod end from steering knockle, disconnect lower ball joint from lower control arm, pry axle out of differential.
Power: Denso IK22 spark plugs, OBX Headers, J32A2 Camshafts, CT SC w/HB
Electronics: Apexi VAFC (untunned)
Gear Box: Rebuilt at 53K ml & at 63K ml by Aamco and still
Suspension: Eibach Sportlines, Koni Sport, Comptech Sway Bars & Neuspeed upper strut bar.
Wheels: 17x7 OZ Racing Superleggara & 215/50 Dunlop Sport A2
Brakes: Legend GS 2 Piston Calipers, Goodridge SS Lines, Endless Nova Pads
Old 05-18-2004, 01:57 PM
aluminumpork aluminumpork is offline
it'll probably end up being $120 for the axle, and you'll get back about 50 bucks for the core (when you bring back the old part), I also had to pick up an axle nut socket ($14 for mine). But all of that is a heck of alot cheaper than bringing it to a shop.
Old 05-19-2004, 05:30 AM
Great...I appreciate the information...
What is the best manuel to buy for this car?
If it clicks when turning left...is it the left or right CV joint?
Old 05-19-2004, 06:35 AM
AccordCodger AccordCodger is offline
I'd say right - that's where the weight shifts to when turning left.
Manual? I'll bet people get downright religious about this, but it partly depends how much detailed help you need. Mine is a Chilton's and it's close to a shop manual -- assumes you are confident (and reasonably knowledgeable) about what you are doing. (Actually, that's a pretty bad choice on my part!!)
