Go Back   Automotive Forums Car Chat > Oldsmobile > Eighty Eight
Eighty Eight Includes the '97-'98 Regency and '96-'99 LSS Models
Old 05-17-2004, 10:04 PM
Restoration67 Restoration67 is offline
Question 1992 Royale 88 3.8 engine crankshaft sensor
Pedestal and sensor seem to be behind plastic dust cover. Does cover come off for removal of sensor?
Old 05-28-2004, 06:06 PM
michtom michtom is offline
Re: 1992 Royale 88 3.8 engine crankshaft sensor
Cover does need to be removed. Carefully pry cover at each bolt-pin attachment point to access crank sensor.
Old 07-15-2004, 02:53 PM
shaz shaz is offline
You will have to remove the harmonic balencer to
replace it. The new one comes with it mounted on
a new bracket. Alignment is critical on this and should not be pried off the bracket a couple of thousands mismatch could wipe it out when you turn the engine over.
Old 10-22-2004, 04:35 PM
latonya latonya is offline
Re: Re: 1992 Royale 88 3.8 engine crankshaft sensor
how did you know for sure that your car needed a new crankshaft sensor? what problems were you having before you used this remedy.
