Old 05-17-2004, 09:44 PM
Skittles12 Skittles12 is offline
Need Some Help Finding A Amp
My freind is about to give to me two 12 inch 600 watt subs. well i know nothing aobut this and i have a alpine CD player with 3 pre amp outputs? so what kind of Amp should i get to send to the 2 subs??? thanks for any help and could you give me a store or website to check out anything you say might be good for the 2 subs. thanks.
Old 05-17-2004, 09:56 PM
sr20de4evr's Avatar
sr20de4evr sr20de4evr is offline
Re: Need Some Help Finding A Amp
what are the subs?
'01 Black Sentra SE
Weapon-R intake, HS header, HKS catback, ES motor mounts, B&M short shifter, Tein coilovers
Alpine 9835, Adire Koda 6.1, Adire Brahma 15, Arc 2100cxl, Linear Power 2.2hv, Cadence ZRS-8
'05 Silver WRX STi
Injen SES Downpipe, HKS Carbon-Ti catback, Cobb Stage 2 Tune, TiC Super Shifter, TiC Klunk Killer, Tein springs, Nitto NT555R Drag Radials
Old 05-17-2004, 10:06 PM
pioneers i think
Old 05-17-2004, 10:10 PM
mjgjr72 mjgjr72 is offline
2,4, or 8 ohm, are they in incloseres if so vented or sealed
http://www.sounddomain.com/
Old 05-17-2004, 10:16 PM
4 ohm
Old 05-17-2004, 10:20 PM
sr20de4evr's Avatar
I mean which specific subs
'01 Black Sentra SE
'05 Silver WRX STi
Old 05-17-2004, 10:24 PM
I am not sure i think it was these, he just got them but doesn't want them anymore.... so i figured i could just use them just to see how it is and stuff.
http://www.circuitcity.com/detail.js...Car+Subwoofers
i think these might be it
Old 05-17-2004, 10:29 PM
sr20de4evr's Avatar
Alright, those subs have a single 4ohm voice coil and can handle 150rms. You have a couple choices for amps
1 - 4ch that puts out 150x2 @ 4ohm when bridged, this amp should do somewhere around 35x4 @ 4ohm
2 - mono amp that does 300x1 @ 2ohm
Either should be pretty easy to find and will work just as well as the other, but the mono amp might be slightly more efficient so it wouldn't drain as much power from your alternator. Personally I would look for a mono amp instead of a 4ch, it should be pretty easy to find. There are so many that I'm not going to bother listing good brands, but you can do some research and post here with some findings, then we can tell you what is good and what is crap.
'01 Black Sentra SE
'05 Silver WRX STi
Old 05-17-2004, 10:32 PM
okay thanks dude, i will look into that.
Old 05-18-2004, 02:24 PM
How about this one
http://www.sounddomain.com/sku/ROCP3001
So do i need to get two amps like this, one for each sub? And could you tell me what kinda wires i need for this?
Old 05-18-2004, 08:46 PM
Nathan4286's Avatar
Nathan4286 Nathan4286 is offline
He probably means one amp, it should do the trick..I'd go w/ 8 gauge for safety reasons, but if you like fire hazards you could go 4 gauge.
Old 05-18-2004, 09:21 PM
aznxthuggie's Avatar
aznxthuggie aznxthuggie is offline
Re: Re: Need Some Help Finding A Amp
Originally Posted by Skittles12
How about this one
yea that is pretty good, and no you only need one amp, im sure u can find a lower price, and since you said you know nothing about it, either buy a 8 gauge amp wiring kit and ask your friends to help u when installing, or get it installed pro somewhere
the amp kit usually comes with power wire, speaker cables, rca cable, wire protector, and a fuse, and lots of ring connectors, maybe a few clamps, i think you can get one for like $25-40 at most places
this is from the rockford fosgate website, you'll want to use the first illustration
http://www.rockfordfosgate.com/rftec...x=1&image.y=19
good luck!
Old 05-19-2004, 06:23 PM
sr20de4evr's Avatar
you really know nothing about electricity do you?
'01 Black Sentra SE
'05 Silver WRX STi
