Old 05-17-2004, 08:34 PM
Snoopyusa5 Snoopyusa5 is offline
Head Gasket Leak
Overflow tank drains about a quart a day. Water pump was replaced but seemed fine. I think the head gasket is leaking, how hard is it to replace the gasket? About how long will it take to replace it?
Old 05-17-2004, 09:32 PM
C_Sephiroth's Avatar
C_Sephiroth C_Sephiroth is offline
Send a message via AIM to C_Sephiroth
Re: Head Gasket Leak
You might have a bad Rad cap, I would try this first.
Homer: No T.V. No Beer makes Homer go... Something Something or another..............
Marge: Go Crazy......
Homer: Don't mind if I do.....muahahahahahbwauauauauauauau
Old 05-18-2004, 12:50 AM
The fluid drains out at night while it is parked. I saw it dripping once, it seems to come out from under the front of the engine.
Old 05-19-2004, 07:10 AM
nova racer's Avatar
nova racer nova racer is offline
you need to find the source of the leak. if you can see fluid on the ground it is not likely that it is a head gasket may be a hose have it pressure tested that is a sure fire way to find the leak
Old 05-23-2004, 08:29 PM
carlos_colion carlos_colion is offline
What nova racer told you is correct, if you see the water dripping maybe is a hose.
Head gasket damaged occur when you overheat the engine and you donīt see any water leaks.
Old 05-23-2004, 10:28 PM
irishgambino irishgambino is offline
If the head gasket is leaking you would probably see white "smoke" coming out the tail pipe. I just replaced mine because of that kind of leak.
I would add to check out your radiatior, a pinhole leak loses a lot of fluid over time, or the petcock at the bottom may have helped itself loose.
/agrees with Nova Racer
