Old 05-17-2004, 08:26 PM
Jim King Jim King is offline
67 Camaro RS Hideaway Headlights
My son and I need help in trouble shooting hideaway light problems. We had the drivers side door motor quit. We replaced and now neither side functions. Any information to help us locate the potential problem would be appreciated.
Old 05-17-2004, 09:21 PM
ridge_runner ridge_runner is offline
Send a message via AIM to ridge_runner Send a message via MSN to ridge_runner
Re: 67 Camaro RS Hideaway Headlights
theres gotta be some sorta switch or relay, i would check into those for starters, and did you hook the motor up right??
Old 05-17-2004, 10:18 PM
89IROC&RS's Avatar
89IROC&RS 89IROC&RS is offline
wow, um.... old school tech haha. so when the driver side motor quit, the passenger still worked? and then you put in the new one and neither workd. im assuming all you disconected the first time was the motor on the driver side. are the two motors wired in parralel, series, or seperate circuits? im not familiar with the wiring of this system, but i suppose its possible that when you hooked up the new motor you shorted something and blew a fuse or something. id bust out a test light and start checking for power on the circuit, test back from the motors untill you get power, then you should be able to find your problem.
Chevrolet Camaro - I enjoy beating the hell out of people
http://www.automotiveforums.com/vbulletin/showthread.php?t=68052
Old 05-18-2004, 01:21 AM
tacoma man tacoma man is offline
i thought some of those were vacuum?
Old 05-18-2004, 09:23 PM
I have been working on the lights and when I manually closed them then pulled the switch they both opened but neither will close. I have tried all the key and switch combinations and nothing happens except for the lights turn on and off but the doors don't close.
Old 05-18-2004, 09:31 PM
Chevyracincamaro's Avatar
Chevyracincamaro Chevyracincamaro is offline
relay perhaps??
Old 05-19-2004, 05:20 PM
89IROC&RS's Avatar
sounds like the switch is bad. if your getting the power to close them, but not open them, i would say only one way of that two way swich is working. some sort of internal failure? have you checked for power on the wires when using the switch? have you checked your connections to the switch?
Old 05-19-2004, 10:52 PM
Do you know were I could get switches?
They don't stock them in year-one
Old 05-20-2004, 07:42 PM
89IROC&RS's Avatar
eh.... not really. but before you buy a new switch, make sure the wire isnt broken somewhere.
Old 05-20-2004, 08:20 PM
esenior esenior is offline
Send a message via AIM to esenior
90% of the '67 RS headlight problems that I have seen ended up being a bad ground. Make sure that you have good grounds to the motors.
Also, if you are grounding to powdercoated parts, make sure you scrape the powdercoating off enough where the wire and washer can get a proper connection.
---Eric
Old 05-21-2004, 02:01 AM
RFoster RFoster is offline
Check to make sure the door is contacting the limit switchs in the full open position.The motors can't reverse and close if the limit switchs are'nt depressed.
Old 05-21-2004, 02:08 AM
Wink Re: Re: 67 Camaro RS Hideaway Headlights
All 67s were electric,68 was the vacuum type.
Old 05-29-2004, 08:41 PM
after all the work the relay was just un plugged
must of bumped it when i was working on the alternator
