Old 05-17-2004, 08:07 PM
bumpinstang77's Avatar
bumpinstang77 bumpinstang77 is offline
Send a message via AIM to bumpinstang77
brahma and brutus
I've been thinking about getting 2 brahma 12's and 2 hifonics brutus 1500's....i found he brutus on ebay for around 250 and the brahmas on adires site for w/e it is there like 379 or sumthin.....is there anywhere else to get the brahmas cheaper and when i do eventually get this system will it run fine off of 2 yellow tops?
Old 05-17-2004, 10:02 PM
sr20de4evr's Avatar
sr20de4evr sr20de4evr is offline
Re: brahma and brutus
No where else to get them cheaper, unless you get them used
And I don't know what you mean "will it run fine off of 2 yellow tops". The system doesn't run off of the battery, it runs off of the alternator. To support that kind of power you're going to need a 250+ amp alternator. I would go with a single brutus and a single brahma 15 instead. It will take up about the same amount of room, your car's electrical system won't die from it, and it will be very comparable in output (won't be quite as loud, but it will be close).
'01 Black Sentra SE
Weapon-R intake, HS header, HKS catback, ES motor mounts, B&M short shifter, Tein coilovers
Alpine 9835, Adire Koda 6.1, Adire Brahma 15, Arc 2100cxl, Linear Power 2.2hv, Cadence ZRS-8
'05 Silver WRX STi
Injen SES Downpipe, HKS Carbon-Ti catback, Cobb Stage 2 Tune, TiC Super Shifter, TiC Klunk Killer, Tein springs, Nitto NT555R Drag Radials
Old 05-18-2004, 03:34 PM
The only way I can do a 15 is firing up...I don't wanna do that...What about a 200 amp alt. and 2 yellow tops...I dunno if they even make 250 for my car I could only find 200.
Old 05-18-2004, 08:27 PM
aznxthuggie's Avatar
aznxthuggie aznxthuggie is offline
i think thats a little too much, it'll have a huge drain on your cars electrical system, i was thinking of one 12/15' XXX and a brutus, i guess you'll need atleast a 200amp alternator, maybe one red top for the starter battery, and one yellow top located somewhere else, for 2 batteries i think you need an isolator, because i think the yellow top was meant more for fast discharge, and you really wouldn't need two yellow tops if ur planning on having two batteries
just put the red top as your main battery, put the yellow top thru an isolator so your system won't drain your red top battery, and wire everything in the trunk, works good? yes? no?
Old 05-18-2004, 09:03 PM
never mind just changed my mind im getting 2 re se 12's as soon as they respond and give me a price.... ill get some brahmas or xxx's later
Old 05-18-2004, 09:15 PM
lol do u really have that much money to spend? if so buy me some friggin subs also eh
Old 05-19-2004, 11:24 AM
GCguy2169 GCguy2169 is offline
Send a message via AIM to GCguy2169
I was going to say, yea that would really fry your electrical system after awhile with 2 brahmas n such. Depriving your Electrical system is very bad. I causes your battery to sulfate on the internal plates, and causes less cranking capacity, and after awhile battery can diminsh in power greatly, 2 yellow tops are VERY hefty in cranking amps, but after maybe months, or even a year and a half, your plates with sulfate and be intolerable of the output.
Old 05-19-2004, 06:18 PM
sr20de4evr's Avatar
yellowtops are deep cycle, they can be drained completely and recharged with no capacity degredation
'01 Black Sentra SE
'05 Silver WRX STi
