Go Back   Automotive Forums Car Chat > Isuzu > Rodeo | Passport | MU
Old 05-17-2004, 07:09 PM
bottlejockey bottlejockey is offline
shifter issues
I'm trying to figure out what is wrong with my shifter. I have all the plastic stuff off around the shifter and when the shifter is in the park position the transmission is actually in nuetral, so I can't get to reverse or park. The rodeo is driving fine I just can't get to reverse or park, it is a 1999 A/T. It is like it went two gears down. Please help. Thanks
Old 05-17-2004, 10:05 PM
amigo-2k amigo-2k is offline
Isuzu Guy
Re: shifter issues
I think, there is an electronic gismo that goes bad with the shifter is in the wrong place. Someone else will have to confirm this.
-Ryan
"tranny range sensor"
http://www.automotiveforums.com/vbul...ighlight=shift
-Ryan
Isuzu Moderator
Car Show Tips
Operations manager with a results-driven passion for process improvement
FAQ 98-04 Isuzu Rodeo, Rodeo Sport, Amigo, Trooper
SOLD - NOV2015 - 2000 Amigo, V6, HT winter, ST summer, 2wd
Old 05-17-2004, 10:08 PM
Question
and where is this electric gismo located?
Old 05-17-2004, 10:10 PM
Isuzu Guy
Re: shifter issues
http://www.automotiveforums.com/vbul...ighlight=range
here is another post.
I'm not sure where is is located.
-Ryan
Isuzu Moderator
Car Show Tips
Old 05-18-2004, 03:03 AM
rodeo02 rodeo02 is offline
Sounds like your shift cable is somehow out of whack. Check to see where the cable connects to the shift arm (and range sensor) out the driver's side of the tranny. Make sure the hold down nut is tight & everything is in place. Have somebody move the gear lever while you are under the truck to see how it's moving.
G/luck
Joel
2016 Subaru Forester 2.5i base CVT
2016 Nissan Quest SV
Old 08-22-2004, 06:25 PM
Guy B. Young II Guy B. Young II is offline
Re: shifter issues
In a kind of a bind. Was working on a '99 Rodeo and found that the inner cable spiral near the tranny has been damaged, so I need to replace the cable ASAP. First question is how much stuff do I need to remove to access the cable at the shift lever, and is this cable available at NAPA, or is it a car specific part from Isuzu? Unfortunately, I'm Manual deficient at the moment.
TIA
Guy
Richmond, VA
