Closed Thread Show Printable Version Show Printable Version | Subscription Subscribe to this Thread
Old 05-17-2004, 05:53 PM
MoochsMalibu MoochsMalibu is offline
Question How to remove stock DIN radio
I recently aquired a 1992 PA with the stock AC Delco cassette player. and I was wondering how to remove it and install an aftermarket cd player? does it require removing the whole dash? and about how long should this job take?
Old 05-18-2004, 06:25 AM
tman's Avatar
tman tman is offline
Pimpin' ain't easy
Send a message via AIM to tman
Re: How to remove stock DIN radio
Malibu- I can change a radio in under 8 minutes, but I've done this about 20 times. first, remove the woodgrain trim alll along the lower dash. This trim hides some screws. Before you take those out, bend up a wire clothes hanger so that it looks like a "V" with little bends on the end, and use it to remove the air conditioner vents. Each vent conceals a screw. Remove all of the screws holding the black upper trim in place, and it will pop off like the lower trim did. Now you have access to the radio. I'd reccommend a delco CD player, they are very strong units. Good luck!
Old 05-18-2004, 07:34 PM
PAman PAman is offline
Malibu...turn vents fully in one direction, push down on top edge sticking out...no nasty scratches from wire implements. Side vents are specific, centers are the identical. Try putting gearshift in neutral(with parking brake set!) before removing black trim.
Old 05-19-2004, 08:28 AM
tman's Avatar
Pimpin' ain't easy
PAman, Let me explain my tool better.
I suppose your way works too though. I'm all about using tools.
Old 05-20-2004, 09:43 PM
Sorry Tman, hope I didn't offend! When I use tools on the plastic stuff in cars, it seems to increase my tendency to break them...
Old 05-21-2004, 01:03 AM
tman's Avatar
Pimpin' ain't easy
No offense taken, I just thought I didn't explain my tool well enough. I never considered just using my hands like that...
Old 05-21-2004, 03:40 AM
padriver padriver is offline
Try this: http://www.carstereohelp.com/stereor...ickLeSabre.htm
I removed my dash according to these instructions, and it worked just great.
Old 05-21-2004, 11:01 AM
tman's Avatar
Pimpin' ain't easy
Thats just like my instructions, except with pictures.
Old 05-23-2004, 11:28 AM
yaeh, pictures are a good thing.
Old 05-23-2004, 06:01 PM
Re: Re: How to remove stock DIN radio
thanks fellas, everything came out just fine
Old 05-24-2004, 10:41 AM
tman's Avatar
Pimpin' ain't easy
Good to hear!
Old 06-17-2004, 09:48 AM
CCW CCW is offline
I am also interested in upgrading my stock 92 and 96 PA radio/tape player to a radio/CD player. Crutchfield (aftermarket audio folks) says that the 92/96 PA well depth (bulkhead distance fore to aft) is too shallow to support a radio/CD player as an integrated unit. Is this true? If so, does anyone offer a split system for retrofit in the 92/96 PA where the player can fit in the glove box, under the glove box, under the seat, etc?
Old 06-17-2004, 02:32 PM
Crutchfield folks are right, basically.
However, it's not impossible. I put a DIN sized radio in my PA, and it works quite well after doing some modifications to the dashboard. I wrote a How To about this issue (in German, but the pictures should explain everything - http://mypage.bluewin.ch/armus/pa/buickradio_ger.htm . Feel free to drop me an email if you need further informations).
Old 06-18-2004, 07:20 PM
Yeah, padriver has it right...you may not need to remove all that he did, but some cutting is needed. Some of the sheetmetal may be bent out of the way. The adaptor kit looks like the same Metra kit I used, and it brings the unit out about 1/2 to 3/4". This helps to fit it in the shallow opening. Be prepared when you go in, and the install will go much smoother. Also, wireless remotes are a wonderful thing in a big car...highly recommended! I have 3 sets of preamp cables hooked to mine, and things are tight in there, but the extra height of the opening helps. Position connectors and wires under the unit to help support it.
Old 08-26-2004, 06:44 PM
mojodojo2k's Avatar
mojodojo2k mojodojo2k is offline
Send a message via Yahoo to mojodojo2k
Thumbs up much oblige...
Just wanted to say that i am about to replace my stock radio in my '94 Park Avenue and that the website: http://www.carstereohelp.com/stereor...ickLeSabre.htm
was a big help!!!! Instead of busting up the dash as i have normally done on past automobiles i actually took some time to see if i could find someone who had already done it. Much oblige to whomever posted that site...i WOULD click the "back" button and find the name of the person, but then i would have to rewrite this reply again..lol!
Closed Thread
