Old 05-17-2004, 04:51 PM
99Zseven 99Zseven is offline
Question Tire size question?
I was wondering if 285 and 305 tires were the same size?? When I looked for 285 Pro Comp tires they went from 265 right to 305 and I couldn't find any 285's. Are they both size 32.8? Also, is it really true that 15 inch rims don't fit on 99 chevy's???
Old 05-17-2004, 06:48 PM
mjgjr72 mjgjr72 is offline
Re: Tire size question?
check tire specs should tell you overall tire diameter, depends if 305/60 or 305/75 ect., pretty sure you need a 16" rim to clear brake caliper.
Old 05-18-2004, 08:53 AM
jeverett's Avatar
jeverett jeverett is offline
Send a message via ICQ to jeverett Send a message via AIM to jeverett Send a message via MSN to jeverett Send a message via Yahoo to jeverett
IT is true that a 15" will not fit. Also, the 305 and the 285 are the same height, the tread area is just a bit wider onthe 305/75. It is the equivilent of a 33x12.50x16, as the 285 is a bit narrower.
1998 ECSB Z71
Whelen LED's
Kenwood 2-way
"BIG 3"
2500+ watt audio
Old 05-18-2004, 10:18 AM
thanks.
