Go Back   Automotive Forums .com Car Chat > BMW > 7 Series
Old 05-17-2004, 10:15 AM   #1
Rudybs2003
Send a message via Yahoo to Rudybs2003
Spark Plugs For 733i (1983)?
I purchased my teenage daughter this car and with a little work it runs great. My loacal Import parts dealer said htis car needs the Bosch Silver spark plugs (wich are a bit expensive; about $9.00each). Is there another type of plug that can be used and give the same performance?
Also I am not able to reset the OBC (On Board Computer) , it keeps polling. Is there a way to test it to dertemine if it is good or how can I reset it ? The last 7 digits of the VIN are 7853203.
Thanks for your advice in advance
Rudybs2003 is offline   Reply With Quote
Old 05-20-2004, 07:15 AM   #2
libertylover
Re: Spark Plugs For 733i (1983)?
The BMW parts catalog calls for Bosch WR9LS spark plugs. Also, if you go to the Bosch website they probably have 2-3 options for your car, though it's a little hard to navigate as I recollect. Here's the link to the Bosch website:
http://www.boschusa.com/home.asp
For the OBC problem, try to disconnect the battery for a few minutes so that it'll reset when you hook it back up. If your car has a radio code you'll need to know it in order to get the radio going again.
libertylover is offline   Reply With Quote
Old 05-28-2004, 12:58 AM   #3
bigsix
The only plugs you should use are Bosch WR9LS.If you do a little shoping around you can find them for aprox. $6.00. They last for aprox.
25,000 miles . Any other plugs will cause a rough idle and stalling.
You shold also NOT use any anti-seize compond as this will cause a heat transfer problem.
Mark Baker
bigsix is offline   Reply With Quote
