okay! i have done my intake and exhaust, i still am not completely satisfied! i own a 91 5.0 and it has 134k miles, i think my rear end is worn out. so i am gonna rebuild the traction lok and add new bearings to it all to get the best of my performance, i think i should replace gears to performance gears that same time too and am not quite sure what gears to get.... i know that ill get a better launch with 4:10, but a friend told me that 3:73 are better if i drive it on the highway alot and ill still get good performance. what would you guys suggest for me? will i notice a big difference?
Re: rear end help!!!!!!!!
4.10's won't do anything unless you have the traction to make the car hook.
General rule of thumb for fox's is; Manual=3.73's auto=4.10's
[size=1]-1950 Ford Custom, flathead V8
-2013 Ford Flex -1999 Ford F150 |
yeah, well i got the 373s and i got a trak lok rebuild kit and rear end kit installed and the end works really awesome! i get really good response now and the first gear is really quick! i love it! now im sortof thinking about getting a shift kit and a aluminum driveshaft.....wat do u think?
I have a 1966 Mustang, and I am unsure about what gears are in it. Is there a way to identify which ones I have. It has a 200 straight 6, but it used to have a 289 in it. I think it came stock with a straight 6 because of the 4 lug drums. Also, what size is it. 8, 8.8, or 9?
It's probably a 9". You can pull the rear end cover off and count the teeth to tell what gear ratio you have. # of teeth on ring / # of teeth on pinion. Ex. 4.10:1 gears have 41 teeth on ring and 10 teeth on pinion.
Re: Re: rear end help!!!!!!!!
Removable 3rd member as in the pinion and yolk?
Yeah, in a 9" all the guts of the center section comes right out. ring, pinion, differential, yolk.. everything. You just bolt all that(called the 'carrier' or '3rd member') into the housing, stick the axle shafts through, and you're done. Thats a big reason why they're so popular for racing... Differential blown? Just pull the axle shafts out a couple inches, unbolt the 3rd member and driveshaft, take out the 3rd member, put a new one in, reattach the driveshaft and slide the axle shafts back in and you're off! Also changing gears or a differential is a whole lot easier. Just take out the 3rd member and work on it on a bench(they make special stands for 9" 3rd members, as well as special jack attachments for removing them). Its really a nice design.
Here's the 3rd member in the axle: http://www.4x4wire.com/ford/reviews/.../axledrain.jpg and out of the axle: http://www.4x4wire.com/ford/reviews/arb9in/pattern.jpg |
