Go Back   Automotive Forums Car Chat > Nissan > Almera | Sunny | Pulsar | Bluebird | Tiida | Versa | NX | Avenir | Tino | Stanza
Old 05-17-2004, 12:12 AM
bluebirdboy bluebirdboy is offline
Send a message via AIM to bluebirdboy
Where to buy a BlueBird
Where should i buy a Bluebird. Does anyone no of anyplace that can get them cheap. Ive been looking for some time now, but im just looking for suggestions. ANd also i was wondering, why is an nx called a B13?
Old 05-17-2004, 02:34 AM
fugiot's Avatar
fugiot fugiot is offline
Send a message via MSN to fugiot
Re: Where to buy a BlueBird
If you want a turbo NX2000, just buy the turbo kit from the bluebird engine and put it on your existing SR20DE. You'll make more power, save money, and keep your high redline. The NX2000 is called a B13 because it's the same chassis as the 1991-94 Sentra. Just a different frame.
SR20 powered SE-R: 60mph-6.2 sec., 1/4mi.-14.7 sec.
VG30 powered Maxima SE: 60mph-7.8, 1/4mi.-15.8 sec.
Don't make me ANGRY
Or I will kick you in teh NUTS
Your NUTS will feel teh steel toe
Teh steel toe that has been in teh snow
I will rip off yuor pants and kick yuo in teh nuts
My steel toe will stick to yuor nuts
And I will swing yuo around by yuor nuts as I do a Hurricane kick
Old 05-17-2004, 02:35 AM
fugiot's Avatar
oops, forgot to tell you...get the SR20DE T25 turbo kit from here:
http://www.jgycustoms.com/serg20/turbokits.htm
Don't make me ANGRY
Old 05-17-2004, 12:16 PM
doesnt the bluebird have upgraded parts, like rods, pistons ...ect? What would give me more horse power, a turbo kit or a bluebird swap?
Old 05-17-2004, 04:43 PM
fugiot's Avatar
The only "upgrades" the bluebird engine has are lower compression pistons and larger injectors. You will DEFINITELY make more power with the turbo kit. The kit comes with the larger injectors and the higher compression of your SR20DE pistons makes extra power without being to hard on the rods. Plus, if you did a bluebird swap you'd end up getting the ecu upgraded anyway whereas with the turbo kit, it's necessary for the install. So there's more power and more money saved right there. Make sure you know what you're getting into though because you'll be replacing tires and transmission monthly if you don't.
Don't make me ANGRY
