Go Back   Automotive Forums Car Chat > Honda > Let's get Technical!
Let's get Technical! Discussion for hardcore in-depth motor heads!
Old 05-16-2004, 10:23 PM
96DxSi 96DxSi is offline
Which distributor?
I have a 96 Dx swap a B16a 1st gen and wanted to change my cap and rotor what car and yr. o yea i have a 95 del sol ecu if that matters?
Old 05-17-2004, 09:18 AM
crxlvr's Avatar
crxlvr crxlvr is offline
Slowest Automatic Civic
Send a message via AIM to crxlvr
Re: Which distributor?
any cap and rotor from a b-series motor will work fine.
Stable Of Cars I have Owned:
1991 Honda CRX
1990 Oldsmobile Cutlass Supreme
2003 Honda Accord
1998 Chrysler Concorde
2007 Honda Civic
1997 Toyota Camry
1995 Saturn SC2
1996 Ford Taurus
1991 GMC Sierra
2002 Daewoo Leganza
1999 Dodge Ram
2007 Honda CR-V
2003 BMW 325i
Old 05-18-2004, 10:38 PM
what about the Distributor?
Old 05-18-2004, 11:56 PM
jcrx jcrx is offline
Send a message via AIM to jcrx
Re: Re: Which distributor?
Any VTEC B series distributor, and you need to get one from the same OBD, so get one from either a 94-95 GSR, or a 94-95 DelSol vtec (B16A3)
Old 05-19-2004, 09:54 PM
so the reason i need the same distributor (OBD) is because of my ecu correct. if thats so, then thats why there were wires connecting seperatley instead to the plug for the distributor.
Old 05-19-2004, 09:57 PM
o yea any good choice of what good brand of cap and rotor and mayb some good sparks wires.
Old 06-30-2004, 12:47 AM
RPMtuner RPMtuner is offline
the reason there are a bunch of wires connected to your distributor insted of a plug is because your wiring harness is stock and some one had to splice it together because the plugs are different
Old 07-01-2004, 03:56 PM
JDMrexBoi's Avatar
JDMrexBoi JDMrexBoi is offline
Banned
did you say your cars a 96 with a 95 del sol ecu the ecu is wrong thats obd 1, it wont plug into your harness you need a p72 96 gsr obdII the p30 del sol ecu wont work the wiring is different!
