Go Back   Automotive Forums Car Chat > Chevrolet > General Discussion
Old 05-16-2004, 09:10 PM
GNXdreamin's Avatar
GNXdreamin GNXdreamin is offline
Jack of All Trades
Send a message via AIM to GNXdreamin Send a message via Yahoo to GNXdreamin
Unhappy 89 Beretta GT throwing plug
Hey, all. i've got a bit of a problem on my hands. I've got an 89 Beretta GT. it's got a 2.8 multi port FI engine. she's got just under 200,000 miles on her. Now, for some reason that i do not know, this one particular spark plug keeps working it's way out (loosening up). I can tighten it up nice and tight, but it just works it's way out again. The threads in the head is fine, not cross threaded, or torn out. and the plug can be tightened nice and tight, but it just comes back out again. i have to tighten it up every couple of days. does anyone have any idea what may be causing this problem, or how to fix it? Any info on the matter would be greatly appreiciated. Thanks!
Old 05-17-2004, 04:58 AM
pcv pcv is offline
The plug may thread in ok and may be tight but is still loose along the threads and works its way out. Only way around this situation is to helicoil the plug hole and reinstall the spark plug. I only hope it is the front plug where it is easily accessible.
Good Luck.
NOTHING LIKE AN OLD CAR.
Old 05-17-2004, 06:51 AM
GNXdreamin's Avatar
Jack of All Trades
Re: 89 Beretta GT throwing plug
Hey, pcv.........Just what exactly do you mean by 'helicoil the plug hote'???
Old 05-17-2004, 06:52 AM
GNXdreamin's Avatar
Jack of All Trades
Hey, pcv.........Just what exactly do you mean by 'helicoil the plug hole'???
Old 05-17-2004, 07:45 AM
GNXdreamin's Avatar
Jack of All Trades
Also, i got a tip from a friend. He says i should try pulling that plug out, and putting some locktight on the threads, and putting it back in. I may try doing that. If it will help the plug stay in longer, then it's worth a shot.
Old 05-17-2004, 09:31 PM
GNXdreamin's Avatar
Jack of All Trades
so.........thumbs up or down on the locktight........INPUT, ANYONE???
Old 05-20-2004, 10:44 AM
Jimmiz71's Avatar
Jimmiz71 Jimmiz71 is offline
Im sure the threads are damaged, if you keep putting it in and it keeps popping out.. take it to a shop and they can re-tapp (re-thread) the hole.. I wouldnt use Lock tite on my car and im not sure what serious heat will do to it. Take it to someone who can fix it right.
-Jimmy
~99' Silverado z71 LS 5.3~
Alpine CDA-9830 Head Unit
2-JLW12 Subs
Infinity Surrounds
Too Many Extras
04' Yamaha YZF R6 Super Sport~
Liquid Silver with Black Ghost flames
K&N Filter, Fender Delete Kit
Aftermarket Mirror Shield
Devil Carbon Fiber High Mount Pipe
Power Commander III
02' Subaru WRX Turbo Sport Wagon
Eibach Springs, Short Throw Shifter
17" Versus Campionato Wheels Wrapped in Pirrelli tires
Old 05-20-2004, 10:47 AM
Jimmiz71's Avatar
also buy another plug dont keep using the same one, im sure those threads are damaged and that will ruin the threads on the hole you keep forcing it into.
-Jimmy
2-JLW12 Subs
Infinity Surrounds
Too Many Extras
Power Commander III
