Go Back   Automotive Forums Car Chat > GMC > Yukon
Old 05-16-2004, 09:52 PM
ccowart ccowart is offline
Send a message via AIM to ccowart
Question 99 Yukon not starting
Im having problems with my Yukon not starting every once in a while. It doesnt happen all the time. Also it does not matter if its cold or hot. i can try cranking it and it just spins over, but not firing. I have checked the fire to the plugs thats good. Pressure checked the fuel line with someone cranking it and i get zero pressure. so i changed the fuel pump, ran fine for 3 days then it started again. relay is replaced, wiring at the pump is good. After a while of playing with it and trying to get it to crank it will finally crank. does anyone have any other ideas to why it is still doing it and whats causing it?? could i just be that unlucky and get a bad pump from the dealer??
Any ideas would be helpful.
Clayton
Old 05-17-2004, 12:32 AM
socal01denali socal01denali is offline
you could have had a series of crud in the lines...did you check your filter for flow??
peace, ryan
Old 05-17-2004, 01:08 AM
well if that was the problem wouldnt my fuel pump come on any way? im not getting any noise from the tank when its wont start.
Old 05-18-2004, 12:16 AM
Eggert Eggert is offline
Re: 99 Yukon not starting
HI,
you may want the dealer put the tech II diagnostic tool on it.
I know, it is costly, but may be worth it.
Take care, Eggert
Old 05-23-2004, 09:10 PM
I think i solved the problem. I took my pump out of the tank again and i noticed a pin on the connector was discolored, like it had been arcing i checked out the connector and it was corroded(sp?). Its been 4 days since i did that and so far no problems. Anyone has this problem i would reccommend checking the connector closely.
Old 05-24-2004, 12:37 AM
nice job ccowart...hopefully it stays running, theres nothing more frustrating
peace, ryan
Old 06-26-2004, 01:44 PM
blakey2000 blakey2000 is offline
my 99 denali wont start either....!
my 99 denali wont start either....! I can spray it in the throttle body and it starts, wheres the fuel pump? and what other things can cause this?
Kevin Blake
Owner - East Coast Muscle Cars
www.eastcoastmusclecars.net
Raleigh, NC
[email protected]
