Old 05-16-2004, 08:34 PM
ACCORD2000 ACCORD2000 is offline
Angry Lost pedal pressure after caliper replacement
I just completed a front Caliper, Rotor and brake pad repacement on my 2000 Honda Accord. I bled the system several times, but cannot get the pedal pressure back. Anyone have any ideas?
Old 05-17-2004, 06:04 PM
Igovert500's Avatar
blue + red light magnet
Re: Lost pedal pressure after caliper replacement
You bled it without pedal pressure? How?
96 3000gt vr4
-K&N FIPK
-Proboost mbc
-Greddy type-s
-ATR downpipe
-no cats
Old 05-17-2004, 07:26 PM
pughdog pughdog is offline
Send a message via AIM to pughdog Send a message via Yahoo to pughdog
You need to get someone to help you? You have to have pressure to bleed brakes. When you pump the pedal, pressure should build up. If you're doing it right.
Old 05-17-2004, 09:03 PM
I discovered that the calipers were on the wrong sides. They have to be right and left specifically. They bolt on either side, but don't work on either side. Go figure.
Old 05-17-2004, 10:04 PM
HONDA_99 HONDA_99 is offline
When your calipers on wrong sides caliper's bleeding screw will be pointed down, if bleeding screw is pointing down you won't be able to bleed air because air is lighter and brake fluid is heavier, heavier stuff settles down in caliper and will come out when you open bleeding screw while air remains in caliper.
Power: Denso IK22 spark plugs, OBX Headers, J32A2 Camshafts, CT SC w/HB
Electronics: Apexi VAFC (untunned)
Gear Box: Rebuilt at 53K ml & at 63K ml by Aamco and still
Suspension: Eibach Sportlines, Koni Sport, Comptech Sway Bars & Neuspeed upper strut bar.
Wheels: 17x7 OZ Racing Superleggara & 215/50 Dunlop Sport A2
Brakes: Legend GS 2 Piston Calipers, Goodridge SS Lines, Endless Nova Pads
Old 05-20-2004, 03:21 PM
rstein13 rstein13 is offline
You replaced the calipers on a 2000 Accord? I have a 2000 Accord with 106,000 miles and I just replaced the rotors and pads 500 miles ago for the first time. I checked the calipers and they were mint! You must be really hard on brakes or else you replaced the calipers when they were still good!
Old 05-21-2004, 02:10 AM
Igovert500's Avatar
If you went 105k on your original brake pads, you must be REALLY loving to your brakes. Also, it is possible he was simply upgrading his calipers.
96 3000gt vr4
-K&N FIPK
-Proboost mbc
-Greddy type-s
-ATR downpipe
-no cats
