Go Back   Automotive Forums Car Chat > Toyota > Corolla/Matrix/Voltz
Old 05-16-2004, 07:20 PM
daveid daveid is offline
replacing 2000 corolla plugs
I dont mean to sound stupid but i dont have enough money to get a manuel yet but are the spark plugs below or above the headers on this? I know that toyotas electrical parts are kinda of delicate and i dont want to jump into something that im gonna fuck up cuz id rather someone else to it but if u guys could help me cuz i cant get the wires to snap off taht are above the headers but im hoping those are them.
Thanx guys for helping the newbie
Old 05-22-2004, 11:11 AM
nhiaxeng's Avatar
nhiaxeng nhiaxeng is offline
Lightbulb Here's what 2 do:
Before you do anything else, make sure you have these:
1. 4 Spark Plugs, not those cheap 1.99 ones that are platinum but the ones that are IRIDIUM, you gotta ask for these they are much much more expensive about 16 bucks a piece
2. 8mm, 10mm, 12mm sockets with a wrench: about 10bucks for a really cheap set but it will do.
3. Spark Plug socket with at least 6" extension bar, make sure they fit the socket wrench you have: less than 15 bucks for both
Here are the steps:
1. Remove the black plastic cover on top of the engine using the 8mm socket. It's held on by 2 nuts and 2 plastic holding thingies (excuse me if I don't know the names). You're gonna have to pry it off the plastic thingies. Don't worry if they break, the cost less than 5 bucks to replace.
2. Using 10mm or 12mm sockets, which ever the fits, remove the plastic RAIL that goes from left to right. There are about 4 nuts. Don't attempt to change plugs or pull out the sparkplug thingies yet.
3. After you are done, the sparkplug thingies are attached to the RAIL by a plastic connector. Disconnect using a lot of care and a screwdriver.
4. Remember, do the plugs one at a time.
5. Pull out the rubber sparkplug thingy by the BOOT not the wire.
6. Insert spark plug socket inside and make sure it fits snug around the spark plug.
7. Rotate COUNTER-Clockwise until it is very loose.
8. Pull out sparkplug. If it doesn't come out, put the socket it, make sure it's on the sparkplug, and do a couple rotations more.
9. Installation is reverse of taking them out.
REMEMBER: DO ONE SPARKPLUG AT A TIME.
BTW: If you don't see a distributer cap, it's because this engine doesn't have one. Better performance
Any questions... please repost it.
