Old 01-17-2002, 01:00 PM
Belldandy's Avatar
Belldandy Belldandy is offline
42 offset?? Please help
I saw some nice rims off groupbuy and they are 17x7 and 4x100 with a 42 offset. Is that good or bad?? Will I get any rubbing?
2000 4dr Civic Ex 'Clover Green Pearl'
Anime Rocks
Kurumi and Naru Narusegawa are awesome!
Old 01-17-2002, 01:08 PM
ric's Avatar
ric ric is offline
Send a message via AIM to ric
should be cool unless your royally slammed. with my civic i was dropped over 2 inches with a set of eibach sportlines (1.7 my ass) and had a set of 17" rims with a 37 mm offset and really only rubbed on hard conering and sharp 90-180 degree turns. after i raised the civic back up with pro kits (not much more) it all but stopped. so you should be fine.
Old 01-17-2002, 01:10 PM
Belldandy's Avatar
Will I get any rubbing if I'm not lowered? My car is at Stock height.
Anime Rocks
Old 01-17-2002, 01:21 PM
ric's Avatar
ric ric is offline
hell no, unless you rally the thing :sun:
Old 01-17-2002, 02:15 PM
Goosse's Avatar
Goosse Goosse is offline
Send a message via AIM to Goosse
Re: 42 offset?? Please help
Those would be the perfect size for a Civic. You won't have any rubbing problems. With the 42offset you could even drop your car for more +2" and still not rub.
Old 01-17-2002, 04:11 PM
Belldandy's Avatar
Nice!
Anime Rocks
Old 01-17-2002, 07:12 PM
dreemkill dreemkill is offline
Send a message via ICQ to dreemkill Send a message via AIM to dreemkill Send a message via Yahoo to dreemkill
since we're on the subject........what /is/ offset? the rota slipstreams i want are 40.........is that bad/good, or is it not a case of good vs bad?
Originally posted by fakirone
.... Nos this, nos that, my 10 second nossy nos will nos your nos.
Originally posted by Prelussion
And then both of you guys w/ you sewing maching powered cars get passed by a moped w/ a 5hp Engine and he goes on to put 5 car lengths on you. Racing an EX vs a DX is like a 10 speed bike vs a golden retriever.
AF Upstate Crew -- Member #1
Current Audio: none. car dead.
Old 01-17-2002, 07:43 PM
drift's Avatar
drift drift is offline
Send a message via AIM to drift
offset is the distance measured between the wheel's actual hub mount and it's relation to dead centre of the wheel. for instance, a deep dish rim has very little offset. on a honda, which most people use a 42-47mm offset, it means if you look at the wheel head on, and imagine a straight line from top to bottom splitting the wheel in half, the lug/hub mount is 42-47mm to the outside from the centre line.
negative offset would mean the hub is inboard of the wheel's centre line.
too much offset reduces the track width of the vehicle, while too little offset can push the tyres out too far and cause fender rub. too little offset also wreaks havoc on your wheel bearings, as the load of the car now stresses the bearings at an angle instead of straight down.
here's a good write up and pictures to illustrate what i'm talkin about: http://www.discounttiredirect.com/helpWheelOffsets.html
please help! -paint estimate helpme1234 Auto Collision Network 1 06-19-2010 07:11 AM
96 Buick Lesabre Squealing Noise. Please help! I don't know what else to do! Jinisu2 LeSabre 6 05-13-2010 10:53 PM
Wheel width/offset help Rooster32 Interior | Exterior | Appearance 0 04-05-2010 10:45 PM
3.4L 1996 Cutlass Supreme Help please!!! Zca62783 Cutlass Series 0 02-14-2009 03:27 PM
wheel offset please?? dbsborg Suspension 1 09-13-2001 03:22 PM
