Old 05-16-2004, 06:20 PM
animal66's Avatar
animal66 animal66 is offline
Send a message via AIM to animal66 Send a message via Yahoo to animal66
Exclamation Front End Conversion
i was lloking at the other post, and the conversion was of a 94+ teg on a 4th gen civic....well the body lines did not compliment each other whatsoever in my opinion. so i was thinking an earlier teg' swap (90' maybe) would look good....maybe even a type R one.....anyone got pics of this? or any links? thanks
Old 05-16-2004, 06:51 PM
Psionic's Avatar
Psionic Psionic is offline
Send a message via ICQ to Psionic Send a message via AIM to Psionic Send a message via Yahoo to Psionic
ITR headlights
same car, outside
s14 headlights (too forced, doesn't fit the car)
00 accord (doesn't look too bad, but the body kit is shite)
90-93 integra headlights (too long for the car, if you want this though I would suggest getting projector headlights. My brother has these on his integra and they look amazing)
RSX headlights: ( )
96-99 Civic headlights
same car with S2000 tails
another with with 96-99 Civic headlights
92-95 Civic Headlights
Stock lights with molded eyebrows:
I am doing 92-95 civic projector headlights on my crx, with a molded eye brow. I purchased the lights on eBay already (goto ebay and search for 92 civic projector tyc). Those lights are really sharp.
Incase, you were wondering, I have over 100 hand-picked CRX pictures on my computer. Yes, I have a CRX fetish.
Old 05-16-2004, 07:11 PM
kicker1_solo's Avatar
kicker1_solo kicker1_solo is offline
Send a message via AIM to kicker1_solo Send a message via Yahoo to kicker1_solo
Re: Front End Conversion
96-00
and the JDM ITR one is the only way to go in my opinion. Even though the 99-00 civic lights do look good.
2000 BMW 323IT
1954 Ford F100
With every post my penis grows smaller
Yakima Valley Truck Club Yakima Washington
Old 05-16-2004, 07:16 PM
Psionic's Avatar
The 92 civic headlights are good with a hood-molded eye brow. I photoshopped one and it looks suprisingly good. I was originally going to go with the japan itr headlights, but they are big $$$ and they aren't chome.
Old 05-16-2004, 10:03 PM
1PhatCX's Avatar
1PhatCX 1PhatCX is offline
just curious on how u did your eyebrows? i wanna mould some on my stock civic but i dunno how i should do them, should i just weld a triangle of metal on the hood over the light? lemme know how u did it cuz i wanna do it before i get the car painted and stuff, thanx man
Old 05-16-2004, 10:12 PM
Ace$nyper's Avatar
Ace$nyper Ace$nyper is offline
Banned
Send a message via AIM to Ace$nyper Send a message via MSN to Ace$nyper Send a message via Yahoo to Ace$nyper
now where the hell the pix of the EF2 lights in it
Old 05-16-2004, 10:22 PM
Psionic's Avatar
I haven't started it yet, but I'm actually making an entire custom fiberglass hood, so the eyebrows aren't going to be a big deal at all, I'll just include them in my fiberglass mold.
If I was using metal though, I'm not sure how I would do it. I know you are probably going to want to attach a thin piece of rubber or foam to the backside of the eyebrow region of the hood, or else you will scratch your headlights when you slam your hood down.
Also, the rubber will make the hood look tighter to the headlight, so it will look less like a rig.
Don't weld a triangle over the light. Give the piece that you weld on to your the hood some curvature, so that it arcs down hard as the curve moves closer to the center of the body (like the pic of that crx I posted)
Old 05-16-2004, 10:30 PM
1PhatCX's Avatar
ok, well i've seen some eyebrows on our cars that are triangular like and they look friggin wild, so i think i might do that instead, would u recommend welding them on? and where would u put the foam? on the bottom of the eyebrow?
Old 05-16-2004, 10:45 PM
Psionic's Avatar
I would do curvature - i've photoshopped both the the curve looks better.
Either way, weld the triangle on the face of the hood so that it is protruding - like sitting intop of the hood. Its hard to explain without a picture.
Once that is done, spray everything with epoxy primer. Once that dries, fill in around the metal with bondo, and the epoxy primer on that. Then paint.
The metal has to be sitting away from the headlight so that it doesn't scrape.
The rubber would have to be roughly the same shape as your metal cut-out piece, and would be mounted on the back of it, so that there is a barrier between the metal and the plastic on the headlight.
Old 05-17-2004, 01:50 AM
Posey88cvic4dr's Avatar
Posey88cvic4dr Posey88cvic4dr is offline
Send a message via AIM to Posey88cvic4dr
Man, never seen most of those....and gotta say S2000 tails rock in that CRX....makes me wish I chose them for my conversion...But I say the ITR are the best
4g4d4Life <--Link To My Car
TEAM CHOZEN
Old 05-17-2004, 02:08 AM
SiZ's Avatar
SiZ SiZ is offline
The only headlights that look even remotley right on a 4th gen are the 2nd gen Teg ones.
Old 05-17-2004, 07:35 AM
1PhatCX's Avatar
i'll try it today and take pics as i go so u can lemme know if u think its right or not, i think i got the idea tho
