Old 05-16-2004, 06:01 PM
Psionic's Avatar
Psionic Psionic is offline
Send a message via ICQ to Psionic Send a message via AIM to Psionic Send a message via Yahoo to Psionic
Help Me Fix My Crx!!!
I was driving one day going easy (~2500 rpm) and my crx just died. I can't get it to start again.
When I hook the battery up to my van and turn the key (in the rex), it turns over but it won't catch. The fuel pump doesn't turn on when I click the key over.
The chiltons said to check to see if voltage is going to the fuel pump, and if there is voltage, get a new fuel pump. Otherwise, get a new main relay.
I hooked up a voltmeter and I'm getting voltage, so I bought and installed another fuel pump used off eBay. But it still won't start. Do you think there is a chance that I got hosed on the ebay fuel pump, and now I have 2 bogus pumps?
Is there another way to test the fuel pump?
Oh I checked the main relay just to be sure and its fine.
Old 05-16-2004, 07:25 PM
Psionic's Avatar
Is it possible I didn't hook the fuel pump up right before putting it in the tank?
Old 05-16-2004, 07:37 PM
JimCRX's Avatar
JimCRX JimCRX is offline
Re: Help Me Fix My Crx!!!
I wouldn't have done that right away. First off, determine if you are getting spark and fuel. When you crank it does it turnover? If so, do you smell gas a little at all? If you smell gas your fuel system is fine. Most common problems to sudden dieing is the distributor. If can, buy a new distributor off ebay for your engine. Also, replace the spark plugs and wires. Then let us know if it fired up or not. BTW, have you replaced the dizzy ever?
Old 05-16-2004, 07:44 PM
Cjz89civic's Avatar
Cjz89civic Cjz89civic is offline
AF Premium User
Send a message via AIM to Cjz89civic Send a message via Yahoo to Cjz89civic
Another common problem is the timming belt sliping check that too.
Mods: D16Z6 Turbo'd P28 ecu and Greddy emanage for fuel. FWD tire smoker
My first Civic love Died from 92 year old Fart not watchin out.
Old 05-16-2004, 10:06 PM
1PhatCX's Avatar
1PhatCX 1PhatCX is offline
or the rotor falling off inside the dizzy cap, mine did that and i dunno how the fuck i managed to drive for 20 mins still with the car backfiring like a mofo! finally it started over heating and i had to pull over and get it towed home that was a sad day cuz i kicked a huge dent in the side of the car cuz i was pissed lol
Old 05-16-2004, 10:07 PM
Psionic's Avatar
Oops forgot to say that it sparks
The problem is definitely fuel delivery
It fired up a little with my brother spraying quick start in the intake manifold while I was turning the key
Old 05-16-2004, 10:10 PM
1PhatCX's Avatar
hmmm, check ur fuel filter, that may be clogged!
