Old 05-16-2004, 05:51 PM
animal66's Avatar
animal66 animal66 is offline
Send a message via AIM to animal66 Send a message via Yahoo to animal66
Exclamation Subwoofer Question
Ok with DVC (dual voice coil) subs, i know you can wire the - to the + on the other coil, but does that deplete any powere? can you wire each coil up to a seperate amp? because im considering getting the new Audiobahn 2000w sub and any 2000w amp is like $1500+, and i dont wanna pay that much. well thanks in advance.
Old 05-16-2004, 06:10 PM
90civicrider's Avatar
90civicrider 90civicrider is offline
www.DecepticonRacing.com
If your going to get a sub rated at 2000 watts, your going to want to put at leased a 1000 watts to it or you will be bottle necking your system.
In other words you will be starving your sub of power.
||JEFF| |
Candy Orange 1990 Honda Civic H/B
Old 05-16-2004, 06:15 PM
animal66's Avatar
Re: Subwoofer Question
what i was asking is, can you get two 1000w subs and wire them to the seperate coils?
Old 05-16-2004, 08:25 PM
2ndb18's Avatar
2ndb18 2ndb18 is offline
Send a message via AIM to 2ndb18
you probalby could but theres no reason. Id just put one 1000w to each sub
you would have plenty of power that would hit hard
88 civic dx
Old 05-16-2004, 10:10 PM
TheSilentChamber's Avatar
TheSilentChamber TheSilentChamber is offline
Forunn Daberator
Dont run one amp to one vc and a differnt amp to the other vc, it will never be equil like its supposed to be unless there linkable amps like ones offered by Cadience. When you wire + - you will drop the ohm rating witch will in theory make your subs hit harder if your speakers and amp are rated for the ohm rating. If you run + + you will retain the same ohm rating as hooking it to say a svc speaker.
Old 05-16-2004, 10:18 PM
Re: Re: Subwoofer Question
If you taking about hooking the subs together, yes you can do that if their dual voice coil. Doing that will lower the ohms and hit much much harder.
Thats how I have my subs hooked up.
2 10" JL's running off a 250 watt mono block amp @ 2 Ohms stable.
If you plan on doing that you will still need about 1000 watts.
The rule of thumb is if you decrease the Ohm load in half, the output power will double..
I could be wrong, but thats what I've been told in the past.
hope that helps.
oh and to hook them up this way do this.
+ on amp to + on sub #1
- on amp to - on sub #1
+ on sub #1 to - on sub #2
- on sub #1 to + on sub #2
||JEFF| |
Old 05-16-2004, 10:24 PM
1PhatCX's Avatar
1PhatCX 1PhatCX is offline
Re: Re: Re: Subwoofer Question
can u do that with one amp running 2 SVC subs? cuz i have like a 250 watt RMS amp powering 2 rockford fosgate subs (old school)
Old 05-16-2004, 10:29 PM
Re: Re: Re: Re: Subwoofer Question
Nope the subs have to be dual voice coil, and your amp will have to support running 2 ohms stable.
||JEFF| |
Old 05-16-2004, 10:33 PM
1PhatCX's Avatar
Re: Re: Re: Re: Re: Subwoofer Question
alright, damn! i was hoping i could do that to get these things to hit harder, do u have any options on what to do to make them hit harder??
Old 05-16-2004, 10:38 PM
Put more power to them. Look up the Specs on the sub and get a amp that fits the subs RMS rating.
||JEFF| |
Old 05-16-2004, 10:39 PM
1PhatCX's Avatar
sounds good, just sucks cuz i dont have money for a new amp yet lol
Old 05-16-2004, 11:22 PM
Jos4DCivic's Avatar
Jos4DCivic Jos4DCivic is offline
Send a message via AIM to Jos4DCivic
Make/buy a ported box and tune it really
big difference over sealed just not as good Sound qaulity. Also sealing subs need more power than if you were to go ported. Ported subs recuire less power as opose to sealed. im guessing you have sealed enclosure.
hopes this help
91 Hatch SI
Heart of my Baby - DOHC ZC - Si tranny - PG7
Finally painted!!!
Old 05-16-2004, 11:29 PM
viridion viridion is offline
Send a message via ICQ to viridion Send a message via AIM to viridion Send a message via MSN to viridion Send a message via Yahoo to viridion
so with DVC there's 2 places on the sub to hook up the wires..
can you create an MS paint schematic of how to hook up all four of the sub hookups (2 subs) to run bridged mono, and for 4 ohm subs would that make 1 ohm or 2 ohm load on the amp?
-Josh
B18A into 90 hatch, daily driver
projects:
all kinds of fun and wierd honda projects/conversions,
funnest is SBC into 90 hatch, RWD conversion, turbo400 tranny.. it's a cut and weld thing
Old 05-16-2004, 11:33 PM
slammedcivicsi's Avatar
slammedcivicsi slammedcivicsi is offline
you guys all need to read some damn tutorials on stereos if you plan on doing anything yourself......check www.jlaudio.com for tutorials.... www.rockfordfosgate.com also has some good ones.
89 DX: LS Powered
88 CX: Project ZC
Old 05-17-2004, 06:14 PM
Ya, those sites will be able to explain it way better than I can
As for the Sealed / Ported box. You need to read the specs and see what it recomends. If you put a sub rated for a sealed enclosure into a ported box, it's gunna sound like shiat. You will also get better sound if your box is the correct size. All subs need a different amount of cubic air room in order to produce the bass frequencies correctly.
||JEFF| |
