Go Back   Automotive Forums Car Chat > Honda > Civic | CRX > '71-'87 Civic | CRX
Old 05-16-2004, 12:29 PM
RSLaser RSLaser is offline
Unhappy Civic wont start
Well, i finally got the igniton drilled out so i can trun it but now it doesnt start! When i turn the key the lights will come on, the horn works, but the dash lights dont come on, and the starter doesnt start the engine, no clicks no nothing....HELP. what can i do? i checked all the wires, and fuses but its been sittine since 85 so i dont know what to do.
Old 05-16-2004, 01:58 PM
cvcc_wagon's Avatar
cvcc_wagon cvcc_wagon is offline
Re: Civic wont start
new battery, sounds like there isn't enough current to trip the solenoid, try jumping it. then go through the circuit between the starter and battery to see if there is anything breaking the circuit
~Attention! if you are thinking about a D16A1 swap for your Civic/CRX and don't know where to start go Here. Thanks.~
Old 05-16-2004, 08:56 PM
The battery is brand new, so we hot wired it to the starter (touched) and it turned over, but wouldnt run...........now what?
Old 05-16-2004, 10:47 PM
cvcc_wagon's Avatar
sitting since 85? what year is it? is it carb ir fuel injected?
Old 05-17-2004, 02:00 PM
Its a 1980, Carbeurated. i was chatting with someone that said since its not firing it might be the coil? is it possible?but the main things are that the wire are all attached but the dash lights dont come on and the the engine wont turn over on its own power...so it might also be the igniiton since i drilled it out?
Old 05-17-2004, 02:48 PM
mechy1barry mechy1barry is offline
obviously youv,e checked the main engine fuses?
Old 05-17-2004, 09:07 PM
cvcc_wagon's Avatar
is the solenoid working? try taking a screw driver to connect the two posts (but make sure you are not touching the metal part...it's gonna spark a little) when you get the engine turning over consistently pull one of the spark plugs to see if you are getting spark, if not it may be the coil, distributor or plug wires. do you know that you are getting fuel?
Old 05-17-2004, 09:42 PM
Well, i think i have...the only fuses i can find are the ones by the hood latch?
i havent tried the solenoid yet, but that may be it. and no im not getting fuel, it wouldnt fire when we sprayed some starting fluid into the carb and truned the engine by hot wiring the starter.
Old 05-17-2004, 09:46 PM
cvcc_wagon's Avatar
well you may be getting fuel then and no spark, check for spark first then worry about your fuel system
Old 05-18-2004, 01:44 PM
if there are no dash lights then you should check under dash for more fuses,(and kickpanels)also tap on any relays with ign on and see if you get a reaction,but i think your prob lies with a fuse as _no dash lamps _no power to starter.more likely to be in engine bay.
