Old 05-16-2004, 12:11 PM
Concord Concord is offline
1997 5.7L quit running
My 1997 5.7L Quit running. It was like it ran out of fuel. I checked the fuel pump, and changed the fuel filter. I know the injectors are not suppling fuel because if I add fuel to throttle body it will start and run for a second. I know nothing about the SCPI fuel injection system. What should I check next?
Old 05-16-2004, 03:27 PM
broughy84's Avatar
broughy84 broughy84 is offline
Check your fuel pressure. You may think that you are getting fuel, but there may not be enough pressure to get them to open the poppets on the injectors. (if i'm thinking right) Definatley check fuel pressure, fuses and relays.
Old 05-16-2004, 06:54 PM
LastOne LastOne is offline
Have a friend or family member crank the truck while you take a rubber mallet or hammer and beat on the gas tank. If it starts, you need a fuel pump located inside the tank. Common problem unfortunatly
Old 05-16-2004, 09:45 PM
OK, thanks I'll get a guage and check the fuel pressure next. Do you know what it should read?
Old 05-17-2004, 01:01 PM
55 to 60 PSI
Old 05-19-2004, 08:25 PM
Thanks to both of you, I have less than 15 psi. I guess I need a fuel pump.
Old 05-20-2004, 04:35 AM
Be sure to go back with an AC/Delco pump. The aftermarket brands won't hold up. If you can stand the wait, usually a good buy can be found on ebay. Good luck
