Go Back   Automotive Forums Car Chat > Car Comparisons
Car Comparisons Compare any cars and find out what every body else thinks. Just refrain from making stupid comparos like Viper vs. Geo Metro :)
Old 05-16-2004, 09:43 AM
3000ways 3000ways is offline
Slalom vs. Skidpad
This just something I always wondered about, and perhaps you guys can answer this for me. Between Slalom and Skidpad, which of the two is the most effective and accurate measuring stick of a cars handling abilities?
Old 05-16-2004, 12:54 PM
Kurtdg19's Avatar
Kurtdg19 Kurtdg19 is offline
Send a message via AIM to Kurtdg19
Re: Slalom vs. Skidpad
I would say either. There is no measurement for handling.
Old 05-17-2004, 02:15 PM
mmont0's Avatar
mmont0 mmont0 is offline
How about how fast you can take a turn without sliding into the grass? That's a test of handling!
Old 05-17-2004, 02:27 PM
2strokebloke's Avatar
2strokebloke 2strokebloke is offline
In Stereo where available
Re: Re: Slalom vs. Skidpad
Skidpad is less dependant on the driver, and therefore makes a better comparision of traction, but the slalom takes into account many more variables, to compare the skidpad with the slalom is kind of like comparing apples with oranges.
Support America's dependence on foreign oil - drive an SUV!
"At Ford, job number one is quality. Job number two is making your car explode." - Norm McDonald.
If you find my signature offensive - feel free to get a sense of humor.
Old 05-17-2004, 05:16 PM
MR2Driver's Avatar
MR2Driver MR2Driver is offline
I'd say lateral acceleration would be the best determinant for a car's handling. That and weight, which effects braking.
Old 05-25-2004, 06:12 AM
lateralgforce lateralgforce is offline
Handling is really a combination of these two factors and a few other variables. It is more of a subjective term than a measurable one. Lateral g-force, measured on the skidpad, is a measurement of ultimate grip/roadholding. Slalom speed is a measure of transitional stability. Other factors that influence handling are surface damping, braking, drive wheel(s), steering effort and feedback.
If you wish to compare cars on this basis, then either drive them yourself and make up your own mind, or look to autocross and track times to give you an indication.
Cheers,
Brian
Old 05-25-2004, 10:02 AM
Mr Payne Mr Payne is offline
I'd tend to choose skidpad. If a car has an incredible skidpad they will likely have a good or reasonably good slalom speed. A good slalom speed does not dictate a good skidpad though. Furthermore, skidpad will ultimately end be giving you the most time on a track due to this.
Old 05-25-2004, 10:31 AM
kfoote kfoote is offline
The problem with both of these tests is that they are both extremely dependent on alignment and tires. Changing either can have a huge impact on both slalom and skidpad numbers.
2004 Subaru Impreza WRX STI (daily driver)
1999 Mazda Miata (track car, slow, but finished the SCCA Runoffs)
1987 Porsche 944 (being rebuilt)
Old 05-25-2004, 03:57 PM
I completely agree...I assume we are talking stock performance though.
Old 05-25-2004, 04:35 PM
flylwsi flylwsi is offline
Send a message via AIM to flylwsi
my thoughts as well...
stock for both, so it's a fair comparison
Old 05-26-2004, 12:20 AM
Jabberwocky Jabberwocky is offline
Most people don't truly understand how course dependent a car's performance is. To illustruate this, imagine a low speed slalom. The fastest way through the slalom is to keep a constant pace. Now take 2 cars, a miata and a Z06. The miata will outpace the corvette because its compactness allows it to take a tighter line. Space the slalom further apat enough, and there is enough room for acceleration to play a part, the results might be different. Now look at skidpad results, the corvette has better skipad numbers. What does this all mean? Neither number is an perfect gauge of handling abilities. But skipad numbers will give you a rough idea of how well the car sticks in a corner, and the slalom times will give you a rough idea of how the car sticks and how fast the car transitions. What skidpad numbers won't reflect is how well tuned the shocks are for example. The slalom if space out enough will be affected by power as well, degrading its value as a measure of handling and just handling.
Old 05-26-2004, 12:24 AM
Let me add that skipad numbers are skewed by the tires the car came with just like slalom times can be skewed by tires and wheelbase. On very good tires, a lousy suspension can pull some fairly skidpad good numbers. But even a great suspension will have a hard time making good numbers on cheap tires.
Old 05-26-2004, 11:17 AM
Thank you for the information.
Old 05-30-2004, 10:24 AM
moslerporschefreak's Avatar
moslerporschefreak moslerporschefreak is offline
I would have to agree. Afterall, the McLaren F1, the finest road legal car ever made, got a .86g on the skidpad. That throws out the skidpad in my mind. Also, as stated before, the slalom is very inconsistent.
STD of the Day: The Gientz- part clap, part e.coli, all misery.
Proper usage: "That skank at the gas station gave me the gientz, where is the restroom?"
Old 05-30-2004, 10:45 AM
I see what your saying, I guess the best test is to see how they perform on the track or drive them myself. Still people don't like that, most people just have to know how a car does, some sort of measurement. So I also agree it's a combination of both, so if car A does a .99g on a skidpad and runs a 70.9MPH slalom and car B on the same skidpad does a .86g and on the same slalom runs a 65.4MPH slalom, one could assume that car A is the better handler. I guess when the numbers are really close, or one is better in the skidpad, and the other is better in the slalom, or vice versa, the only way to get an accurate sense of what is better is to try both cars out.
