Old 05-16-2004, 09:01 AM
taurusblues taurusblues is offline
Removing a Taurus abs light bulb
Help..
I need help in how to remove the ABS light bulb. The light won't go off and I know the brakes are fine. I need to have the light off so I can pass inspection.
TB
Old 05-17-2004, 09:41 PM
irish30's Avatar
irish30 irish30 is offline
Re: Removing a Taurus abs light bulb
You should have it scanned to get the code out it buutt, if you want to remove the bulb you need to remove the instrument cluster. The bulbs are popped into it on the rear of the cluster.
Old 05-17-2004, 11:00 PM
jjdewd jjdewd is offline
Send a message via AIM to jjdewd
AutoZone Auto parts stores here in NH will scan and clear codes for free. Or let you use it.
My last car passed inspection with the ABS light on
Old 05-17-2004, 11:20 PM
irish30's Avatar
If you can get the codes I may be able to let you know what they mean. There is another posting here for abs light on after moving the vehicle, if you want to know how to test the wheel speed sensors.
Old 07-14-2004, 12:55 PM
Chapol Chapol is offline
I've tried black electric tape to cover the light and it worked well. Cheap and easy!
