Go Back   Automotive Forums Car Chat > Jeep > Wrangler
Old 05-16-2004, 09:00 AM
serpenteyne serpenteyne is offline
universal joint damage
my son lifted his 94 jeep wrangler and since has been snapping his rear universal joint. says when he is making a turn left or right at a moderate speed he hears nosie then joint snaps.
has anyone had this happen and whats the fix for it
thanks
please post or email me at [email protected] with responce
Old 05-19-2004, 01:16 AM
Moab Man's Avatar
Moab Man Moab Man is offline
Re: universal joint damage
How much lift does he have?
Has he done a SYE?
Old 05-19-2004, 09:33 AM
he did a four inch suspension lift, and he called me the other day and said that he was told it was the rear axel spline that was lose. what is a sye?
Old 05-19-2004, 09:48 AM
Moab Man's Avatar
Rear axle spline? I'm assuming he means the yoke coming out of the front of the rear differential and not the axle splines that are internal of the differential.
The SYE (Slip Yoke Eliminator) is corrects the driveline angle of the rear driveshaft. A tall lift can cause binding and possibly breakage.
Sent you an email.
Big Jeep, lots of stuff.
Old 05-27-2004, 05:26 PM
John-the-Limey John-the-Limey is offline
Maybe he needs to point the rear 3rd member directly towards the output of the transfer case. This is done by "cheese-wedge" shims between the rear axle and the spring mounting plates. If his 3rd member is paralell to the ground, a lift kit will increase the driveshaft angle enough to break u-joints. Another fix is to drop the transfer case one and a half inches by using 6 spacers between the skidplate and the frame.
