Go Back   Automotive Forums Car Chat > Oldsmobile > Aurora
Old 05-16-2004, 08:23 AM
trevorzane trevorzane is offline
Send a message via AIM to trevorzane
How do I diagnose power window problem??
None of my windows will go down from any panel..the problem started in the back drivers side...it would roll down and be stuck down for awhile..then one day they all the sudden none of them would work..!!.I was thinking if I changed that motor they would work..hopefully..if not how do I diagnose the problem?..with some device?? any suggestions would be helpful!!
Old 05-16-2004, 08:45 AM
97 silverbullet's Avatar
97 silverbullet 97 silverbullet is offline
Send a message via AIM to 97 silverbullet Send a message via Yahoo to 97 silverbullet
Re: How do I diagnose power window problem??
is it the drives door switch that controls all the windows doing it, or is it all the switches doing it. if so your drivers switch is broken and just replacing it should fix it, but if they are all doing it with all the switches I'd check fuses.
[On his running for California Governor]
It's the most important decision I've had to make since 1978 when I decided to get a bikini wax.
-- Arnold Schwarzenegger
Politics is not a bad profession. If you succeed there are many rewards, if you disgrace yourself you can always write a book.
-- Ronald Reagan
"I wrote a book"
--Bill Clinton
Old 05-16-2004, 09:28 AM
its all the switches..i couldnt find fuses just for the power windows just a breaker..its the sunroof /powerwindows breaker under the back seat..the sunroof still works..plus i used another breaker in its place and still no luck..if anyone knows where the power windows fuse is please let me know..!! thanks
Old 05-16-2004, 01:51 PM
kev's 96 Aurora's Avatar
kev's 96 Aurora kev's 96 Aurora is offline
Send a message via AIM to kev's 96 Aurora Send a message via Yahoo to kev's 96 Aurora
I have a similar problem...My driver door power window cluster works all windows but the other windows won't go down with there own switches, and no the lock out is off...when I got the car I noticed it had two 12v power points down by the ash tray...the one on the right had a dime in the bottom and when I pulled the dime the aux unit didn't work...this leads me to believe that a fuse is blown BUT will it be tied to the power window switches...I don't have a sunroof and I would think that all the windows should be tied together so why would the driver door work.
Just got a '96 Aurora
89k miles
Mods: Airbox, 20% tint
Very powerful car.
Old 05-24-2004, 06:39 PM
I finally figured out the problem w/all my windows..i pushed on the boot in the door where the wires run from the door to the car and my passenger side windows started working..i took off the boot and found two broken wires and more that was about to break..so i reconnected the broken wires and taped up the ones that was nearly broken..the only window that doesnt work now is the driver door..i can hear it clicking but not going down..it worked before they all went out..dont know why it doesnt work..any help would be appreciated on that..i hope this helps out other aurora owners..
