Old 05-15-2004, 08:16 PM
davideo davideo is offline
Post Service Engine Soon On after I changed Sparkplugs
I just replaced the plugs in my 2000k Chevy 1500 with a 4.8 8 cyl Engine with 55K miles and the light came on and it has a rough Idle. I checked all the wires on all are secure.
Is there a engine reset like for the oilchange ?
The new plugs are Bosch Platinum 4 Link - >
http://www.boschusa.com/AutoParts/Sp...PlatinumPlus4/
I looked in the Manual and it just says change at 100K mi and it gives part #.
*** IT ALSO SAYS ITS AN EMMISION SERVCE ***
Thanks
Old 05-15-2004, 11:50 PM
bmfzo6 bmfzo6 is offline
Re: Service Engine Soon On after I changed Sparkplugs
why would you change plugs at 55k. never use the bosch or you are asking for trouble. possible cracked plug causing it to run rough.
Old 05-16-2004, 12:01 AM
TheJamster1 TheJamster1 is offline
The only way to tell is to isolate the misfiring cylinder. You take a wire loose from the plug (leaving it on loosely) crank it up and pull the wire off (with some kind of insulated pliers) and see if the engine RPMs change or the engine misses worse. If it does move on to the next one until you have isolated the dead cylinder. The easy way would be to hook up a scan tool and read misfire data. Codes if you have a code reader are :PO301 is cyl#1, PO302 is cyl#2 get it??
Old 05-16-2004, 01:33 AM
GMMerlin's Avatar
GMMerlin GMMerlin is offline
I know stuff
Thanks
Well you just wasted time and money!
I would reinstall the old plugs and see if the skip goes away....then the next time you want to put that Bosch crap in your truck, save yourself some time and just send me the money
probable senerio is that you may have cracked a plug during installation or you got a bad plug.
Why do you never have enough time or money to do the job right the first time, but enough time and money to do it again?
Got all the certifications
25 years ASE Certified Master Technician
GM WCT
Yea..I work at a DEALERSHIP....got a problem with that?
Want to diagnose cars like the Pros? FOR SALE: OTC Perception 2 channel Labscope (badged as a Matco Reality)
This is my personal labscope that I use to diagnose waveforms, like new, comes with leads and training video
PM Me for details
Old 05-16-2004, 07:50 AM
feac feac is offline
Re: Re: Service Engine Soon On after I changed Sparkplugs
Helllo,
I agree with you 100%. "davideo"
can you send me some photos of the plugs? [email protected]
Thank you
Adam Forsythe
Old 05-16-2004, 09:23 AM
Lightbulb Re: Re: Re: Service Engine Soon On after I changed Sparkplugs
Originally Posted by feac
Helllo,
Thank you
Adam Forsythe
Here is the link... I am going to take out and examine the plugs.
Why is the bosh plug so bad and what do you use ?
Thanks
Old 05-16-2004, 09:37 AM
GMMerlin's Avatar
I know stuff
Re: Re: Re: Re: Service Engine Soon On after I changed Sparkplugs
Thanks
I use and recommend A/C Delco plugs and wires to my customers.
I also do not recommend replacing plugs unless there is a driveability issue that can be resolved with plug replacement or until the manufactors recommended service interval.
Plus I have seen alot of driveability issues caused by some of the aftermarket plugs out there....don't trust them..don't use them.
GM WCT
PM Me for details
Old 05-16-2004, 12:48 PM
Come to find out I had a cracked plug on # 1 Cly. It was also hard to put the original back in. I cleaned the old plugs and replaced em and it runs smoooth.
How can I reset the Service engine soon light !! ??
Old 05-16-2004, 04:28 PM
Great news, after 10 mins driving it went off. Computer must of seen all was well again... Thanks for ALL your help everyone...
