Go Back   Automotive Forums Car Chat > Volkswagen > Jetta/Vento/Bora
Old 05-15-2004, 08:13 PM
bladez bladez is offline
Send a message via MSN to bladez
Question where to find hazard and signal relays?
i have a problem with my 1985 jetta its hazard and signal lights won't work nd i want to know the advice of everyone that has had this problem nd fixed or a way to fix it??
bladez
Old 05-16-2004, 01:02 PM
Kimtaz Kimtaz is offline
If I am not wrong, the relay for the hazard and signal is one and the same (at least it is in the 96 models). If you look under your steering wheel, by the fuse box, there should by a couple of relays plugged in with numbers on them. The hazard/signal one is labled 191. I bought mine for about $10 from the dealership.
Old 05-16-2004, 01:59 PM
boschmann boschmann is offline
Re: where to find hazard and signal relays?
Turn signal/Hazard relay is in position #12 (lower right) on the fuse relay panel under the driver side dash.
Old 05-16-2004, 05:34 PM
the relays rn't really marked so i have to guess which one it is so if i know wut it looks like and where do get a replacement then it will be all i need
Old 05-17-2004, 05:19 PM
Most parts places should be able to get this relay. It is the lower right relay on the panel.
