Old 05-15-2004, 09:05 PM
mattscar mattscar is offline
Question Fuel & Temp Gauge max out when driving forward
I have a 1992 with auto transmission and replaced the engine. Everything worked fine until I dropped a valve. Replaced valve and piston and all cylinders back to 150 psi. Engine works great but when I put it in gear and drive the temperature gauge and fuel gauge max out. Stopping at a light the gauges slowly drop back to normal. Can't find any missing grounds. Anybody have any ideas on this problem?
Old 05-15-2004, 11:51 PM
geozukigti geozukigti is offline
You might have a bad voltage regulator in your alternator. That's my best guess. Turn your headlights on, and rev the engine, and see if the lights get brighter when the RPM's go up.
Old 05-16-2004, 11:53 PM
Re: Fuel & Temp Gauge max out when driving forward
The lights stay the same. As r=this was happeneing, bought a reconditioned regulator and it still happened. Had it checked and was OK. Picked one up in junk yard and the same thing happens.
Old 07-01-2004, 12:24 PM
dave_k672 dave_k672 is offline
Send a message via MSN to dave_k672 Send a message via Yahoo to dave_k672
Mattscar, My fuel gage is doing the same thing. Did you ever figureout your problem?
Old 07-01-2004, 12:30 PM
Check the ground behind the center console under the dashboard.
Old 07-06-2004, 08:48 PM
Phain Phain is offline
is like Samurai?
I have a Samurai, not a Metro, although I'm planning on getting a Metro. I have done many mods and repairs to my Sammi. A thing that comes to mind in this thread is that we have a similar problem with run-away fuel and temp.
(background)
I have no idea if the wiring is similar. In the Sammi there is a voltage regulator (I think it is) in one of the gauges. The wiring diagram will show it as a coil around a core, just like the ones that control the needle movement. The needles move by the movement of a bi-metal element. The element is heated by a ni-chrome wire wrapped around it, the current rate determined by the sensor. The regulator is similar, except when it gets hot and bends, its bi-metal strip opens an electrical contact. The internal resistance of the ni-chrome wire knocks the voltage down that flows through the coil, and to the gauges.
(my idea)
In the Sammi, a wire frequently burns in two, coming from the regulator coil to the gauge coil. All current for both gauges is sourced through this coil. When the wire is burned, the gauges receive full 12v and peg-out, unless the fuel level is *really* low, and/or the engine is cold. It is easy to take the Sammi cluster apart and solder a wire back and fix it. Worth checking, anyway.
Old 07-12-2004, 04:18 PM
WissNX01's Avatar
WissNX01 WissNX01 is offline
Banned
Send a message via Yahoo to WissNX01
You could have a cross short. Providing the speedo is electronic, your fuel and temp gauges might be shorted into the speedo. This might cause wierd readings.
Old 01-08-2009, 10:30 AM
bansheetaz bansheetaz is offline
did anyone have any fixes for this? i have a 95 thats doing this same thing.
Old 01-09-2009, 05:14 AM
Woodie83's Avatar
Woodie83 Woodie83 is offline
Yes, geozukigti posted the fix above. The instrument cluster is not getting it's ground that it needs to operate properly.
Woodie
98 Metro and 06 Aerio SX
Don't waste your vote on one or the other of the Republicrats, vote for Gary Johnson and really do something for a change
http://www.garyjohnson2012.com
