Old 05-15-2004, 07:10 PM
Jaymes's Avatar
Jaymes Jaymes is offline
failed attempt at stripping paint
Everything else is perfect and ready to go except for the body I haven't touched it for months and now that I have more free time I decided to finally complete the model.
The problem lies in the remaining paint in the crevices and lines of the body. Anyone have an idea of how I can fix this? Or is it just better to reorder another body? This was dipped in Pine Sol, and the plastic started feeling brittle so i took it out. I have heard about Castrol Super Clean and brake fluid, but will these melt the plastic?
Any inputs would help, thanks
Some pics:
Old 05-15-2004, 07:26 PM
m.c model master m m.c model master m is offline
Re: failed attempt at stripping paint
what kind of paint is it
Old 05-15-2004, 07:32 PM
Jay! Jay! is offline
Horizontally Opposed
Gently run the tip of a toothpick through the crevices. Often, the bond between the paint and plastic has been weakened, but the geometery of the surrounding plastic is holding those little bits in place. You may be able to knock them loose with some coaxing.
Hierarchy of Subaru:
(Click to see mine!)
Old 05-15-2004, 07:41 PM
if you got the paint from tamiya just take a candy color and paint it. after tat put a nother color that match the candy coulor paint over it.lets say tha you put clear gold you spray it after take red and spray it over the red to make it look good
Old 05-15-2004, 08:08 PM
SailorMoon SailorMoon is offline
Send a message via AIM to SailorMoon Send a message via Yahoo to SailorMoon
I keep hearing wonderful things about brake fluid (not brake cleaner).
Old 05-15-2004, 08:40 PM
I've had more success with CSC than brake fluid (not brake cleaner). Just my .
That said, stubborn paint sure is stubborn.
Old 05-15-2004, 11:01 PM
freakray freakray is offline
AF Modelrater
Re: Re: failed attempt at stripping paint
Congratulations, you get the "most random post of the week award"
Seriously, where is the relevance of your post to the subject of the thread?
AF User Guidelines
Old 05-18-2004, 03:31 AM
2GU UP's Avatar
2GU UP 2GU UP is offline
Send a message via MSN to 2GU UP
hahaha i was thinking exactly the same thing
Old 05-18-2004, 06:08 AM
proosen's Avatar
proosen proosen is offline
A warning about brake fluid! Stay with dot 3 or lower, I tried dot 4 and it shure took of the paint in a hurry. The problem was that it took the body to It melted the plastic about halfway through so now I have a Lotus Europa with everything but the bodypanels. The upside of this is that I can tell everybody else what happend so you wan't do the same mistake as I did and I have a lot of spareparts for the next on I buy. Some sort of alcohol takes acrylic paints away swift and easy, Mr. Muscle owen cleaner does the job just fine on enamels, but not on Tamiya spray colors. Don't know anything but brakefluid for that one.
Niclas
Old 07-05-2004, 05:14 PM
Jaymes's Avatar
hey guys I just dipped the body in Castrol Super Clean, but I remember a guy melting his Ferrari Modena 360 body from CSC. I'm a little worried since the body isn't completely covered with paint and that the CSC will melt the model too any suggestions as to how long I should leave it?
btw - make sure you wear gloves ahahah
Old 07-05-2004, 06:02 PM
AF Modelrater
The amount of time you leave the body in CSC shouldn't matter, you'll probably want to leave it in for at least a day though.
AF User Guidelines
Old 07-05-2004, 06:11 PM
From where do you remember that? I've never heard of it.
I've left plastic model bodies in CSC for months with no ill effects...
Old 07-05-2004, 06:34 PM
Jaymes's Avatar
hmm that's strange I CLEARLY remember a guy asking where to get a spare ferrari body because the CSC warped his body...
well what you say relieves me, and hopefully things will turn out well
Old 07-05-2004, 07:46 PM
Although... Make sure you get the right stuff. Castrol has a couple products branded "Casrtol Super Clean." You want to buy the cleaner/degreaser and nothing else.
Old 07-05-2004, 08:32 PM
Jaymes's Avatar
checked thanks for your help
