Old 05-15-2004, 06:27 PM
T-Rouble T-Rouble is offline
Changing out Ext. Cab Window
I need help I have to change out the frame around my ext cab pop-out window on my 98 Silverado. Does anyone know how to do this?
Old 05-16-2004, 01:13 PM
Levi(WA)'s Avatar
Levi(WA) Levi(WA) is offline
Re: Changing out Ext. Cab Window
Hi,
Wish I could help you, I know how it feels to no get a response to your question, this will put it back on top tho...
[img][/img]
Levi
1998 Silverado Z-71
1966 Chevelle
1964 Impala
1974 Porsche 914-2.0L
Old 05-17-2004, 08:20 AM
jeverett's Avatar
jeverett jeverett is offline
Send a message via ICQ to jeverett Send a message via AIM to jeverett Send a message via MSN to jeverett Send a message via Yahoo to jeverett
Sorry, I have absolutely no idea.
1998 ECSB Z71
Whelen LED's
Kenwood 2-way
"BIG 3"
2500+ watt audio
Old 06-11-2004, 09:21 PM
mjgjr72 mjgjr72 is offline
pretty sure its a complete assebly and is glued in and needs to be cut out with wire like front window. then clean out old adhesive, apply new adhesive and hoppfully set new one in straight.
Old 06-12-2004, 11:29 AM
walbern1 walbern1 is offline
So the glass is OK but the frame is bent, rusted or something? Can you see how the frame is held on?
Old 06-13-2004, 03:33 PM
jeverett's Avatar
If it is one of the side windows, you need to remove the plastic panel inside the door. IT should just pop off with some effort. Then you can access the bolts that hold the window in. I did this on a Ranger the other day.
1998 ECSB Z71
Whelen LED's
Kenwood 2-way
"BIG 3"
2500+ watt audio
Old 06-13-2004, 07:33 PM
tidalcock tidalcock is offline
Getting the old one out may not be too difficult, but putting the new one in properly is tricky. The proper alignment and sealant are critical to keeping out water and air noise. Had mine done earlier this year by a local glass company and they not only did it wrong the first time, but they broke the interior door panel and had to replace it at their cost. This is one job that I woould recommend leaving to someone who has done them before and can back up any mistakes they might make.
Good luck.
