Old 05-15-2004, 05:41 PM
mnKISSgirl mnKISSgirl is offline
Question Disabling SIR (Air bag) system
HELP! Ok, trying to check my wiring behind the dash, and I'm told to disable my air bag system before doing so (according to Chilton's manual). The diagrams aren't clear enough, but I think I can spot where the CPA's are at. I don't want to f' anything up - so can anyone tell me exactly where the connectors are located under/near steering column? And also what all needs to be disconnected? I've already disconnected negative battery cable and removed the fuse...
Thanks!
jen
Old 05-15-2004, 09:15 PM
equalizr equalizr is offline
Take all fuses out related to the airbags?
Old 05-16-2004, 10:20 AM
Re: Disabling SIR (Air bag) system
Yep - but I need more detail....
Anyone??
Old 05-16-2004, 11:51 AM
C_Sephiroth's Avatar
C_Sephiroth C_Sephiroth is offline
Send a message via AIM to C_Sephiroth
Disconnect the Battery For 5-10 min, and then before reconnecting Rem the Air bag fuse
Homer: No T.V. No Beer makes Homer go... Something Something or another..............
Marge: Go Crazy......
Homer: Don't mind if I do.....muahahahahahbwauauauauauauau
Old 05-17-2004, 12:46 PM
Re: Re: Disabling SIR (Air bag) system
...yes - read the post - I've already done that.
Does anyone else have experience with disconnecting the CPA's near the steering column??
Old 05-18-2004, 02:16 PM
STYLEZ24 STYLEZ24 is offline
Send a message via MSN to STYLEZ24
disconnect your battery and do what you have to do.. your airbags arent going to go off... I've had my dash apart many times.
Old 05-19-2004, 11:45 AM
droppedz droppedz is offline
Send a message via AIM to droppedz
^^^ like he said disconecting the battery will be enough and taking out the fuse is a plus but thats alls you need to do I left my fuse out and took out my passenger side air bag and soon driver when I get my new steering wheel in.
Old 05-20-2004, 12:13 PM
Why, thank you very much Mister STYLEZ24 - I appreciate your expertise... I kind of wondered why it just HAD to be disabled, since the system can only carry a charge for another 10 minutes after the battery is disconnected.
Cool!
