Old 05-15-2004, 04:00 PM
trigger_y2000 trigger_y2000 is offline
GM 700 shifting problems
I have a rwd cutlass v8.At operating temps when comming to a stop the trans - torque converter seems to not unlock.It is like trying to stop a car with a manual trans without disengaging the clutch.What tells the convertor to unlock.Is there a simple fix or is a rebiuld in order
Thanks Scott
Old 05-15-2004, 06:51 PM
quaddriver quaddriver is offline
Send a message via AIM to quaddriver Send a message via MSN to quaddriver Send a message via Yahoo to quaddriver
sure its a 700? if the rwd olds has a 3.8 or 5.0 (A or Y code) then its a 200, SOME cutli were built with the H code and the 700, but the problem is the TCC solenoid which does fail in the 200 - easy to fix too - drop the pan and there she is.
MagicRat's Avatar
MagicRat MagicRat is offline
Nothing scares me anymore
Re: GM 700 shifting problems
Its quite simple. There is an electric solinoid switch inside the transmission that is getting stuck. This needs to be replaced. You need to drop thr transmission pan to get to it. While you are in there you may as well change the filter and clean up the pan too.
This is a common problem in '80's 4 speed automatics.
Old 05-15-2004, 07:57 PM
Thanks all.I think I can handle that.
Scott
