Go Back   Automotive Forums Car Chat > Saturn > Vue
Old 05-15-2004, 12:38 PM
sumdeus sumdeus is offline
Location of oil filter and plug
Could someone direct me (with pictures if possible) to where the oil filter/plug is located at on a 2004 3.5L V6 Saturn VUE. I am attempting my first oil change but cannot find the oil filter and plug. Any help would be greatly appreciated.
David
Old 06-06-2004, 08:18 AM
04SilverVue 04SilverVue is offline
Send a message via AIM to 04SilverVue Send a message via Yahoo to 04SilverVue
It is right behind the passenger site wheel well.
2004 Saturn Vue FWD V6
3.5L V6, 250HP
www.tbwilson.com
www.saturnfans.com
Old 10-14-2004, 06:58 PM
SaturnMan62 SaturnMan62 is offline
Plug
fyi,
The drain plug is a 17mm.
Old 10-14-2004, 07:00 PM
Re: Location of oil filter and plug
Also, it is easier to get at the filter if you turn the steering wheel all the way to the right.
Old 11-21-2004, 05:08 PM
drewjmore drewjmore is offline
Re: Re: Location of oil filter and plug
The '17mm' post saved me. I think I was working on a completely different plug (perhaps the transfer case?)-- I was in front of the driver side wheel and it had a 3/8" (female) square drive. Lucky it wouldn't budge, or I'd never have come inside to look this up. No more crack for me.
I also noticed that the oil-pan has an embossed "engine oil" label nearby, once I got onto the correct side (passenger) of the car. Also, it helps to be left-handed when turning the filter.
QUESTION: Is there any way to keep the filter from running over as you remove it? It seemed like the housing to which the filter connects was still holding a few ounces, even after the oil-pan had finished draining.
Old 11-21-2004, 08:37 PM
sierrap615 sierrap615 is offline
Master Tech Wanna-be
Re: Re: Re: Location of oil filter and plug
on my S-series i always put the pan under the filter, loosen it a turn or two, wait for it to drain, then remove the filter, it keeps things a little cleaner
Old 12-07-2009, 08:45 PM
jimdris jimdris is offline
Smile Re: Location of oil filter and plug
This thread definitely saved me some time - I had crawled around under my 2005 Vue for 20 minutes looking for the filter.
