Go Back   Automotive Forums Car Chat > Toyota > 4Runner/GX470
Old 05-15-2004, 12:03 PM
paul5333 paul5333 is offline
Check Engine Light
I just replaced the starter (not easy) on my 94 4runner and now my check engine light is on. The electrial system seems to be working fine. How can I reset the light and see if it is just a fluke. I really don't want to take it to the dealer.
Old 05-15-2004, 06:30 PM
uk4 uk4 is offline
With the ignition turned off, remove the EFI fuse (15A) for 20 seconds before replacing it. This should clear the codes in the ECM memory and reset the check engine light.
Old 05-18-2004, 06:43 PM
Re: Check Engine Light
Thank You, that worked perfectly.
Old 05-20-2004, 10:06 PM
ToyotaTech ToyotaTech is offline
it will be back on
Old 05-21-2004, 10:44 AM
Why? What can I do to make sure it stays off? The vehicle is running great now.
Old 05-21-2004, 11:00 AM
VTISC007 VTISC007 is offline
If it goes back on, you need the service book, it has a list of the codes needed to figure out what is wrong with your Runner.
It tells you how to do it. You have to short a couple of terminals in the diagnosis plug, then turn the ignition on without starting it; the check engine lite will then start to blink. According to it's blinking pattern (it's code), you need the book to tell you how to decipher it's code. It will pretty much tell you exactly what's wrong, or at least give you a good hint as to where to start.
Old 05-22-2004, 01:23 AM
light came on because something was wrong and now u cleared the code. should have check the code before clearing it.
