Old 05-15-2004, 02:32 AM
brokeasscracker brokeasscracker is offline
Banned
Send a message via AIM to brokeasscracker Send a message via MSN to brokeasscracker Send a message via Yahoo to brokeasscracker
Popping windows
I have a 98 eclipse and everytime i go to rolldown my windows they make a loud popping noise. Is this common or is it just my car? Anyone know what the problem is and know how to fix it?
Old 05-15-2004, 04:12 AM
NOFX0617's Avatar
NOFX0617 NOFX0617 is offline
Send a message via AIM to NOFX0617
my windows do the same thing. as long as yours are manual windows and not power windows then i think its a normal thing.
1998 Eclipse GSX
6 Bolt swap
MHI Big 16g
FP Race Manifold
Apex'i N1 Cat-back
Apex'i N1 Downpipe
Walbro 255 fuel pump
GReddy Type S BOV
Turbo XS Boost Controller
Balance Shaft Elimininator
ACT 2600
RRE 11lb No Name Flywheel
Prothane Motor Mounts
Tokico Illuminas Advanced Handling Kit
RRE Front and Rear strut tower bars
RMDSM Front and Rear Sway Bars
TRE Stage 2 Tranny
ARP Head Studs, Main Studs, Rod bolts
Old 05-15-2004, 09:17 AM
Import2nr99's Avatar
Import2nr99 Import2nr99 is offline
Re: Popping windows
the popping is probably caused by the windows seating in the trim. it puts pressure on the window (they're curved) and "seals" the window. when you roll it down, the pressure is released and the windows go back to being more curved. it is possible that things could have warped over time (these cars are getting old) but I wouldn't think it would be anything to get worried about. as long as they don't leak, or break. you're good to go.
V8's are like tampons, every pussy needs one!
Old 05-15-2004, 12:33 PM
1stGenRocks's Avatar
1stGenRocks 1stGenRocks is offline
Send a message via AIM to 1stGenRocks
Re: Popping windows
check out dsmtuners they have a article about how to fix that. its not good for the windows to pop
-1stGenRocks-
95 Tsi AWD: 6 bolt, DSMLink, 880's, ACT 2600, lightweight flywheel, AGX's, Dropzone springs, poly motor mounts and suspension bushings, 3 inch turboback, gus modded 1g BOV, hardpipes, drilled & slotted rotors, 17's
plans: bastard 20g, water/meth injection NO FMIC
Old 05-15-2004, 01:28 PM
duckydsp's Avatar
duckydsp duckydsp is offline
Mine does that. I found the source of my problem. My window goes over the seal instead sitting in it like its supposed to. That makes it stand straight, then when you roll the window down the window goes off of the seal and curves again which makes the popping noise.
DSF
1998 Green Mitsubishi Eclipse GS- Vibrant Ram Intake, Greddy Evo2 cat-back, front and rear strut bars.
2 Kicker L7s, amp coming soon
17" white Motegi RT5 rims, Quwhees 12-piece wide-body kit will be put on....... someday
