Go Back   Automotive Forums Car Chat > Opel/Vauxhall > Corsa/Barina
Old 05-15-2004, 12:25 AM
alltheusrnamesgone alltheusrnamesgone is offline
Remove the radio?
Hi,
I'm trying to install a new radio in my Corsa. Problem is, the old blaupunkt that is in there doesn't want to come out.
Has anyone removed a radio from one of these (without a crowbar!) and if so what was the trick??
Thanks!
Old 05-23-2004, 06:30 AM
alexpag's Avatar
alexpag alexpag is offline
Send a message via MSN to alexpag
What year was it build, what model is it a,b,c?
Old 12-22-2004, 05:54 PM
sduenas sduenas is offline
Re: Remove the radio?
You have to remove a bolt in the back side, is very difficult, maybe you need the help of another person with a little hand. This is the only secure for the radio.
Old 12-28-2004, 09:27 AM
Sophie-Dee Sophie-Dee is offline
Did it yesterday with mine, it takes a lot of tugging and a small hand, take the bolt at the side at the back n just keep wiggling it and tugging it
Old 12-28-2004, 05:48 PM
Ian Griffiths Ian Griffiths is offline
Having the right tools makes it loads easier, U shape things, you have these?
Old 01-07-2006, 11:13 AM
bamurphy bamurphy is offline
Re: Re: Remove the radio?
Where abouts are you?Have you got the Head Unit Out and jus the cage left or is the head unit still in? if the head unit is still in and the U tools wont fit, that is because there are 4 grub screws int he HU, a small allen keys sorts them out and then the U tools will work.
BA
Old 10-15-2006, 12:03 PM
cnes1977 cnes1977 is offline
I live in uk and own a 2001 corsa club. The stereo is a blaupunkt 2003 (cassette player). I have the grub screws out and the holes exposed. I've attempted to use the dinn keys, but I can only remove one side of the head unit. The passenger side will not release. Can anyone help??? I don't want to damage the orginal unit.
Old 09-07-2007, 03:22 AM
BarinaBrett BarinaBrett is offline
Use small allen keys, push them in their whole length. After removing the grub screws. Put your hand in the coin pocket under headunit and pull while jiggling it up and down.
Old 09-07-2007, 03:24 AM
you will have to damage the original unit if you wish to use the plastic fascia.
