Old 05-14-2004, 09:13 PM
superman0604 superman0604 is offline
Bronco Questions
How can you tell what size engine a 1988 ford bronco has. I have looked under the hood and there is no sticker that says.
Old 05-14-2004, 10:32 PM
burnM's Avatar
burnM burnM is offline
Re: Bronco Questions
302 - 351 if it's a V-8
1977 GMC Jimmy - daily driver-sitting on 33's and bedliner inside and out
1995 9C1 Caprice - winter beater
1994 Impala SS - newest project
1991 9C1 Caprice - (rip)
"There are two great problems in the world today; an ever-growing lack of common sense, and too many warning labels. Take away all of the warning labels and the problem will work itself out..." -B
Old 05-14-2004, 10:51 PM
Re: Re: Bronco Questions
Yes it is a v-8 but how can you tell if it is a 302 or a 351. Also do you know what the spark plug gap is? I also have a problem with the blinkers. If you think you could help.
Old 05-15-2004, 01:25 AM
burnM's Avatar
I don't know too much about Fords, I'm more of a GM guy. Maybe check into the Bronco forum... it's listed under the Ford forum.
More than likely though, your engine is a 302 or smaller
Old 05-15-2004, 09:20 AM
MagicRat's Avatar
MagicRat MagicRat is offline
Nothing scares me anymore
The 351 has a taller deck height, that is the intake manifold is approx. 1 1/2 inches wider than a 302. As I have sold all my 302 stuff, find a friend/ neighbour who has a 302 (Mustang??) and measure the width of the intake manifold and compare it to yours.
Old 05-15-2004, 11:10 AM
Also the blinkers do not work. They do not blink on the dash or the taillights or anything. What could be the problem.
Old 05-15-2004, 06:31 PM
MagicRat's Avatar
Simple. Check the fuse. Is it blown? Use a test light. Is it getting power? If okay:
Check the flasher unit. (round cylunder about 1 x1 inch, usually found on the fuse panel). Swap in another one that you know works and see if that makes a difference. If not, is it getting power?
Check the bulbs, and the ground wires for the bulbs. If a lightbulb is burned out or a wire is bad, sometimes that makes all the lights on that side not work. However, if nothing works, it may mean you have bulbs burned out on both sides.
Otherwise, you have a wiring problem.
