Go Back   Automotive Forums Car Chat > Ford > Bronco
Old 05-14-2004, 08:39 PM
waverous waverous is offline
Low vacuum
Recently rebuilt a 351W and installed SEFI. When I initially started the engine, I had to rotate plug wires around the cap one spot in order to get the engine to fire. When I attempted to time the engine, I noticed the timing marks were off significantly - about 30 degrees AFTER TDC - not BTDC. Engine ran fine though. Next, I noticed I was only pulling 8" of vacuum. Before buttoning up the engine, I did ensure cam and crank marks lined up on TDC. Any advice on where to start fixing this problem cause I assume they are both related to one another. Thanks for the help
Old 05-16-2004, 09:25 AM
97chevyman's Avatar
97chevyman 97chevyman is offline
Re: Low vacuum
what do you have for a cam?
2000 ford F-250 4x4 CC auto
1978 F150 4x4, 6 inch lift painted john deere green
Old 05-17-2004, 09:43 PM
ridge_runner ridge_runner is offline
Send a message via AIM to ridge_runner Send a message via MSN to ridge_runner
Re: Low vacuum
did your timing jump?? did you install a new timing chain when you did the motor
Old 05-18-2004, 07:29 AM
Found out the HB is mismarked for my application. The engine is an 84 and the HB from NAPA is for an 85 on up. Didn't think it made that big of a difference, but when I took it off and lined the new HB up with the old worn one according to the key position, there was a 20 degree difference between them. I remarked the new HB and now have 18" of vacuum
