Old 05-14-2004, 07:17 PM
american american is offline
Coolant Problems (help please)
I just bought a 1985 z-28 camaro (125k miles). It was running great until today when I was gunning it down the highway. I didnt watch my Temp guage (D'oh!) but after I pulled up to my friends house a few minutes later I noticed my coolant was leaking because it was boiling out of the cap and smoking :/
The temp when I looked at it was around 230, after I let it cool down for about 5min to take it home it went back down to normal during driving.
People said it could be a number of things:
There isnt a 50/50 ration of coolant to water.
A radiator problem.
A valve or something (rember, im a noob) is working properly.
I havent gotten it checked it out yet, and I know the real experts are propably here
Any idea why it was boiling or how to fix it would be greatly appreciated.
Thanks!!
One more thing, the fluid level was at Full Hot, and now its down to almost nothing.
Thanks again for any help!
Old 05-14-2004, 08:48 PM
DaMoNe6969's Avatar
DaMoNe6969 DaMoNe6969 is offline
Re: Coolant Problems (yes, im a newb)
Did it overheat just on the highway? Sounds like your thermostat is just stickin closed.. They are cheap, and simple to replace..
Is it still overheating?
1991 Camaro Z28
Old 05-14-2004, 08:56 PM
90 RallySport 90 RallySport is offline
thats a real nice car, yeah check the thermostat
mine done that too. it was stuck.
1990 rallysport camaro 5.0 5 speed baby
Old 05-15-2004, 11:42 AM
4onFloor's Avatar
4onFloor 4onFloor is offline
take off those luvers and it'd probly help. lol
Old 05-15-2004, 01:54 PM
ridge_runner ridge_runner is offline
Send a message via AIM to ridge_runner Send a message via MSN to ridge_runner
lol yea i think it would look hella nice with out the louvers
Old 05-15-2004, 03:24 PM
pfox_64 pfox_64 is offline
Thermostat definatly
Old 05-15-2004, 03:36 PM
89IROC&RS's Avatar
89IROC&RS 89IROC&RS is offline
well, first things to look at, is the cooling system all orignial/?? waterpump, radiator, hoses????? thermostat, all that stuff. if it is, my guess is a part failed.
but heres a test. jump in and drive the car around the block once or twice, then pull over with the engine running and pop the hood. there are pretty much five key parts to the cooling system the block(waterpump), radiator, thermostat, cooling fan system, and the hoses. with it sitting there idling, get out, check if your fan is on, if its not get in and turn your A/C on, then check again, your fan should be running. if its not, the fan is bad. if it is running turn the A/C back off. now, check for heat in the system. naturally the block will be hot, dont grab that. grab a hold of the upper radiator hose. is it warm?????? if it isnt, chances are your thermostat is stuck closed. if it is, move to the radiator and CARFULLY touch the cap, it SHOULD be HOT!! if its not, your radiator is probly clogged or something, if its hot, grab the lower radiator hose, is that hot??? should be if its not, probly also means the radiator is cool. now, if the upper hose is cool close to the radiator, but hot close to the block, you could have a bad water pump, and there is no coolant flow, and the coolant in the hose is being heated by the hot fluid coming out of the open thermostat. but there isnt enough heat transferrence to heat the coolant close to the radiator. if the cooling system is hot everywhere, and the fan isnt running while its overheating, it could be one or more of the following. the fan motor, which you can test by turning on the AC as stated above. the fan temp switch on the passenger side of the block above and in front of the starter motor. or the cooling fan relay on the firewall in front of the driver. hope that helps.
Chevrolet Camaro - I enjoy beating the hell out of people
http://www.automotiveforums.com/vbulletin/showthread.php?t=68052
Old 05-15-2004, 05:58 PM
DaMoNe6969's Avatar
yeah... what he said
1991 Camaro Z28
Old 05-15-2004, 06:36 PM
-= c a m a r o =- -= c a m a r o =- is offline
Send a message via AIM to -= c a m a r o =-
Re: Coolant Problems (help please)
A radiator problem.
i thought the coolant doesnt do anything except prevent corosion, water would do the same thing as coolant only it would cause corrosion. or am i wrong?
"A silly Civic Si owner who confidently revs on an LS-1 powered Camaro at a light, cocky in the fact that his engine makes more power per liter, is going to get swatted like a pesky little fly, VTEC or no VTEC." - Mike Kojima, Sport Compact Car Magazine
Old 05-15-2004, 06:44 PM
68chevelle 68chevelle is offline
Send a message via AIM to 68chevelle
coolant is a blend of anti-freeze and water. idealy a 50/50 blend. get it... ANTI-FREEZE. in the winter it keeps your colant from freezing. it lowers the temerature at witch it will freeze. yes it prevents rust and all that stuff too. straight water would freeze at higher temperatures and it would make things rust.
Old 05-15-2004, 06:50 PM
but it doesnt do nothing to cool the engine better than water
Old 05-15-2004, 07:11 PM
DaMoNe6969's Avatar
You still need to have properly mixed coolant.. Too much water, and your cooling system will corode, and parts will fail prematurly.. Too much coolant, and it will gel at high temps..
But I doubt thatd be the problem
1991 Camaro Z28
Old 05-15-2004, 07:37 PM
i dunno if it does or not. it could. but there are adaatives that you can add that do make the mixture disapate heat faster. 40 below is one along with water wetter and there are others.
Old 05-15-2004, 08:33 PM
4onFloor's Avatar
not trying to pick at you Iroc, but the fan switch is in the pass. head not the block
Old 05-16-2004, 12:32 AM
Chevyracincamaro's Avatar
Chevyracincamaro Chevyracincamaro is offline
water transfers heat better than coolant. all the coolant does is prevent the water from freezing and from boiling away while it cools the engine. now a days its all formulated to prevent corosion. ive always heard that you dont have to have 50/50, that its just recommended. i generally only run with about 1/4 to 1/3 coolant in the summer for obvious reasons...one of you guys want to prove me wrong and explain the 50/50 thing???
