Go Back   Automotive Forums Car Chat > GMC > Sonoma | S-15
Old 05-14-2004, 03:41 PM
wrzaman wrzaman is offline
Angry New Motor Wont Start
I swapped out a blown 1997 2.2 for a 2001 2.2 and made what I thought were all the proper changes (intake & Exhaust Manifolds, 1 sensor for the fuel lines and the EGR/Air Warmer thing on the back of the head). The original wiring harness was used as well as the original ECU and everything plugged in properly. Now everything is back together and the key wont kick the starter over. When I turn the starter with a screwdriver the motor turns and i get spark as well as fuel pressure but I dont think the injectors are firing. The only possibility that i can see is the sensor on the transmission that shows shifter positioin and park/neutral safety. It was cracked slightly when removed. Any help would be greatly appreciated or confirmation that the trans sensor could cause these problems. I really dont know where else to look
Old 05-15-2004, 06:40 AM
GMMerlin's Avatar
GMMerlin GMMerlin is offline
I know stuff
Re: New Motor Wont Start
The trans position switch does provide power to the solenoid side of the starter relay.
Starter relay provides power to the starter solenoid.
Why do you never have enough time or money to do the job right the first time, but enough time and money to do it again?
Got all the certifications
25 years ASE Certified Master Technician
GM WCT
Yea..I work at a DEALERSHIP....got a problem with that?
Want to diagnose cars like the Pros? FOR SALE: OTC Perception 2 channel Labscope (badged as a Matco Reality)
This is my personal labscope that I use to diagnose waveforms, like new, comes with leads and training video
PM Me for details
Old 05-15-2004, 08:09 AM
Thanks, thats confirmation enough for me.
Old 05-20-2004, 05:01 PM
Bought a new park/neutral/trans position sensor and now the motor starts by jumping the terminals where the starter relay is but when the brakes are hit the motor turns off and the brake lights are always on. Key still wont trigger the starter relay which is good.
