Old 05-14-2004, 01:41 PM
tim62 tim62 is offline
93 caravan rough idle
my minivan has an idle that keeps getting rougher and rougher. have had codes checked but din't come up with anything. also tried carb carb cleaner in gas, no diff. i would appreciate any help
Old 05-14-2004, 01:48 PM
slantsixness's Avatar
slantsixness slantsixness is offline
Re: 93 caravan rough idle
How about a vacuum leak?
a burnt valve?
bad throttle position sensor?
Low compression?
clogged Catalytic converter?
Bad O2 sensor?
bad thermostat?
Need a tuneup?
It doesn't necessarily have to throw a code to have a problem.
slantsixness
If I knew what I did to break it, I would've known not to do what I did.
www.classicwinnebago.com
Old 05-16-2004, 09:54 PM
BleedDodge's Avatar
BleedDodge BleedDodge is offline
Send a message via MSN to BleedDodge
IAC valve?
