Old 05-14-2004, 01:37 PM
Andydg Andydg is offline
Electric Cutouts
Anyone ever use these on thier turbo charged Eclipses??? What brand did you buy??? Are you happy with it??? How does it sound??? TIA.
Old 05-14-2004, 01:45 PM
LandoAWD LandoAWD is offline
Send a message via AIM to LandoAWD
Re: Electric Cutouts
A friend of mine has a manual cutout (obviously the same except you have to crawl under the car), and it sounds NASTY when it is open.
As for brands and stuff, perhaps one of the other guys can help you out.
Kris
2012 Genesis Coupe 2.0t
Old 05-14-2004, 02:02 PM
ashah000's Avatar
ashah000 ashah000 is offline
Send a message via AIM to ashah000
What is a cutout? Is it one of those things on the exhaust that you can have it going through it or just open it up?
For Sale 98 Eclipse GS, 5 spd
Old 05-14-2004, 09:10 PM
JoeWagon's Avatar
JoeWagon JoeWagon is offline
Banned
Yes. If you are curious as to what it would sound like, disconnect your downpipe from the cat. I did this recently because I'm a closet ricer (and was curious), and it sounded absolutely terrible. I have no idea how my car can sound so shitty compared to my friend's WRX. I put the bolts back in about 20 minutes later.
Old 05-15-2004, 04:02 PM
Is there much of a HP increase??? Because I'm getting an Evo III manifold, and a 3" downpipe, and already have a 2" or 2 1/2" Apexi N1 Catback, and an "aftermarket" cat. So I'd like it to be as unrestricted as possible. Then a little off topic, but it would be a waste to start a new one...How long should it take me (novice mechanically) and a friend (built his exhaust system on his '86 Chevy 3/4 ton) to put in the Evo III manifold and the downpipe??? Again TIA.
Old 05-15-2004, 05:18 PM
Import2nr99's Avatar
Import2nr99 Import2nr99 is offline
it's all bolt on. the hardest part will be getting the old bolts off probably. just spray them down with wd40 or an equivelant and go look at your pretty parts and figure out how they go on. once you're done doing that, go back and take it all apart. quick and easy.
I hope your apex is 3" and that was just a typo. plus the DP will get rid of your "aftermarket" cat. it'll be a little louder, but it's worth it. Good luck, hope you enjoy.
V8's are like tampons, every pussy needs one!
Old 05-15-2004, 06:17 PM
The downpipe gets rid of the cat??? Now I don't have to go in for emisions ever, except if a cop notices it missing, so I dunno about that. As for the N1, i'm 95% sure it's not 3", probably 2 1/2".
Taking the bolts off was what I figured would be the toughest part, and I'm deadly afraid of busting off one of the studs, I've done that before on my dirt bike and I thought that I'd learned my lesson.
Old 05-15-2004, 06:45 PM
if it's an N1 downpipe, and N1 exhaust, for a turbo, then it's 3". and thats a good thing, so don't worry. also, if the DP is an N1, it removes the cat. If you have emissions just save the stock stuff for inspections. and a cop shouldn't pull you over, it won't be that loud, and if it is get the silencer.
Just make sure to spray down the bolts before you go tryin to twist them off. and you'll be fine. just make sure you're on it nice and tight.
Old 05-15-2004, 09:08 PM
Alrighty...Thank you very much for all the advice.
Old 05-17-2004, 03:39 PM
KWandKD KWandKD is offline
The N1 is 3inch (they dont sell anything smaller for the turbo) and the downpipe does eliminate the cat - so just find a mechanic buddy and slip him 40 bux to pass your car, or just do what import2nr suggested.
The sound is alot better, it doesnt sound like a ricer its pretty much the ideal sound for an import. I love it -
Old 05-17-2004, 04:55 PM
BadlanzHPE BadlanzHPE is offline
Electric cutouts
Check mine out.
www.badlanzhpe.com
Enjoy!
Badlanz
Old 05-18-2004, 10:36 AM
gelman4u gelman4u is offline
Send a message via AIM to gelman4u
if you do have problems with the studs, just heat them up with a oxy-acetylene torch, just 2 flats will make it tons easier. Mine were a b*tch to get out with wd40 so i borred my friends torch...much easier.
as for the exhaust, i could not find any n1's that were less than 3" which is what i have on my car and i love it. i live in a town with probably 50 cops to patrol a boring suburb, and i have never been pulled over from my exhaust. i was accused, however, of dui at least 40 or so times. It's my tires i swear. :P
